wheels rubbing arches mot fail!!!
Old Jun 4, 2005 | 01:19 PM
biggy_j's Avatar
biggy_j
Default wheels rubbing arches mot fail!!!
hi guys,
i took my car for an mot and it failed. i have got everything sorted except the wheels are rubbing the arches at the front. They are 17" and are on a 1988 escort cab.
What can i do to overcome this problem? I dont have a spare set of 15" wheels with decent tyres sat around unfourtunatly!
Jonny
Old Jun 4, 2005 | 03:59 PM
adamS2RST's Avatar
adamS2RST
Why are they rubbing tho? How low is the car, surely there is a problem with the suspension setup? Ir is it they are catching on lock? If it is all ok then i'd raise the suspension a tad
Old Jun 4, 2005 | 10:44 PM
biggy_j's Avatar
biggy_j
the suspension is lowered 20mm. they are only rubbing on full lock?
Old Jun 5, 2005 | 04:14 AM
HybridBly's Avatar
HybridBly
sounds like a very strict mot station to me i have 16's and lowered 60mm and have rub still passed mot 3wks ago
Old Jun 5, 2005 | 07:12 AM
nigel b's Avatar
nigel b
put wheel spacers on the front for the mot
about 5mm should work
take them off after
Old Jun 5, 2005 | 08:56 AM
james_birch's Avatar
james_birch
borrow someones 15's for the test! then put your 17's back on after! do it just outside the mot station!
Old Jun 5, 2005 | 09:22 AM
RSeb's Avatar
RSeb
yeah i've had this, rubbing on full lock just stick some 15's on for the mot and change em back over later, it's perfectly legal in a way, as soon as you drive out the station ur car is fit whatever hapens after that is ur busines
Old Jun 5, 2005 | 06:33 PM
biggy_j's Avatar
biggy_j
like the sound of the spacer thing. any idea where to get them from?
thanks
jonny
Old Jun 5, 2005 | 06:56 PM
sufsRS's Avatar
sufsRS
i think its the mot tester being ay too strict take it elsewhere!!!
Old Jun 6, 2005 | 08:12 AM
biggy_j's Avatar
biggy_j
the thing is he has let it pass on loads of other things that i know r wrong with it so i would be a fool to take it elsewhere!
Old Jun 6, 2005 | 08:33 AM
Nice_aRSe's Avatar
Nice_aRSe
Your wrong, a car can pass an MOT and be non road worthy the day after.
An MOT is only based on the DAY it was tested
Old Jun 10, 2005 | 06:02 AM
MattC578's Avatar
MattC578
I think he means the car is fit its passed the test you can go put your wheels back on and make it (apperantly) unroad worthy
Old Jun 11, 2005 | 07:25 AM
biggy_j's Avatar
biggy_j
got my wheel spacers today so i will see if that works!
charlierothwell
Ford KA
Nov 5, 2015 06:56 PM
Kam B
Sep 24, 2015 10:40 AM
Adam Graham
Sep 6, 2015 06:04 AM
andrewmctiernan
Wheels and Tyres
Sep 3, 2015 08:22 PM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
