Closed Loop wiring
I have a H reg sapph 4x4 with older wiring as opposed to the late sapphs.
Firstly, what kind of wiring is it ? Ive forgotten
Secondly. When i was down and MSD stu breifly mentioned closed loop wiring but said as i only do 4/5k a year the cost probably wouldnt be worth my while.
Im still intrigued, can someone enlighted me to the advantages of closed loop and what it involves & cost etc.
Thanks.
Thanks.
I had stu fit closed loop fuelling to my 2wd saff.It worked a treat.I was getting up to 38mpg from my stage 3 car.I have removed it now due to a new engine.I still have the full kit at home with instructions.If you are interested in buying it then let me know mate.
Regards, Adam.
Regards, Adam.
Regards, Adam.
Regards, Adam.
the closed loop isnt only to save you fuel...
it makes the car idle/drive better too!
sygjim i was going through my emails the other day and recognised your name from when i bought a 3 bar map sensor off you from ebay some time ago.
for a 4x4, if it's a red top model, you will need the lambda sensor wiring up to the ecu, but you can do that yourself. then all you need is a chip from either a green top ecu if you only want a standard map, or you need one from stu or elsewhere that has the closed loop routine written in to it.
stu has a winter sale, see his post in the general section. £220 for a L8 closed loop chip.
In fact, i think that i will put some grey in my motor and if i can, next year, i will put closed loop and live mapping, but i need to learn english before
So, i need some advices in this post https://passionford.com/forum/viewto...569&highlight=
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
