metering units
I've stripped and rebuilt mine. I will never do it again. Not fun. CasperR - I thought you would only get chatter from an MFi if you were running higher boost?
problem i get with mine after tacking it apart is it starts then cuts straight out, before it missfired on 2 cyliners but when it does run it runs on 4 now
Steve Escos
Oct 1, 2015 06:57 AM
