bleeding brakes
Old May 26, 2005 | 08:34 PM
turbo.jon's Avatar
turbo.jon
Default bleeding brakes
ive ripped all abs off car and now got all bits from 3i on instaed just i cant get rid of all air in system.car failed mot yesterday because of it had a try again today still no good so unless there is any magic way its going into garage tomorow to have it done ive been using an easy bleed kit but aint no good still air in it
jon
Old May 26, 2005 | 08:40 PM
radiant red's Avatar
radiant red
If ya can get a mate or your lass to help ya, try doing a bit on each corner going opposite sides. Just a bit at a time, dont forget to keep ya finger over nipple when the pumper is pumping.
Old May 27, 2005 | 12:13 AM
adamS2RST's Avatar
adamS2RST
I had loads of trouble with mine recently, and the abs is going next week I got my mat Lee to use a pressure bleed kit, seemed to work well, no pumping crap, straight out
Old May 27, 2005 | 07:33 AM
turbo.jon's Avatar
turbo.jon
cool will get garage to do it then as i aint got 1 of those
cheers
jon
Old May 27, 2005 | 08:39 AM
adamS2RST's Avatar
adamS2RST
Mate they are called "eezibleed" £13 odd from halfrauds. Attach the hose to your tyre and it uses the tyre pressure to blast the fluid out, worked well with mine when we couldnt get a pedal
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
