Accralite Piston problems?
Old May 25, 2005 | 08:48 PM
pacificzetecturbo's Avatar
pacificzetecturbo
Default Accralite Piston problems?
My engine siezed up a week ago and after taking the engine out and the sump off i found a worn shell and assumed it was that. Anyway took the crank out and it turns out No3 conrod is siezed in the piston or the gudgen pin is siezed in there. What was the problems people were saying about accralite pistons from burtons? I need some guidence before i phone them and kick off!
Old May 25, 2005 | 08:51 PM
Ginge !'s Avatar
Ginge !
just finding my feet
it wasnt burtons fault !!!! its the older pistons that had the problem ,, ok should be
but speak to zvhturbo as he had the same issue with his
Old May 25, 2005 | 10:48 PM
Rossco's Avatar
Rossco
When you say older pistons....... how old???
Old May 25, 2005 | 10:53 PM
Ryan's Avatar
Ryan
Just sounds like oil starvation.
Worn Shell.
Seeized Rod.
Could be wrong though
Old May 25, 2005 | 10:55 PM
essexrsturbo's Avatar
essexrsturbo
the normall problem with these pistons is the comp ratio, not fuking shells ect..
Old May 25, 2005 | 10:59 PM
Rossco's Avatar
Rossco
Yep thats the problem we were all talking about the other day. have not heard of them munching into the pins before.
Old May 25, 2005 | 11:00 PM
Šhatter Box's Avatar
Šhatter Box
trouble with the pistions r u got to skim them so much to get the comp down which is not all good for them but worn shells is what ryan said
Old May 26, 2005 | 09:55 AM
Stratos RS's Avatar
Stratos RS
Up for the day people!
Old May 26, 2005 | 10:02 AM
essexrsturbo
i would say oil starvation
Old May 26, 2005 | 10:08 AM
Stratos RS's Avatar
Stratos RS
how long would it take to sieze with low oil pressure though? i think it's strange how an area that has no direct oil feed would sieze so quickly? could it be a piston fittment error?? is that possible?
Old May 26, 2005 | 10:21 AM
Stratos RS's Avatar
Stratos RS
anyone?
Old May 26, 2005 | 10:23 AM
essexrsturbo
not long with no oil pressure mate, but could also be a failure somewhere... who built it?
Old May 26, 2005 | 10:37 AM
pacificzetecturbo
who built it?.............. "Burton"
Old May 26, 2005 | 10:52 AM
Stratos RS's Avatar
Stratos RS
Burtang!
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
little bram
Oct 4, 2015 12:13 AM
timsrs
22
Sep 24, 2015 08:14 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
ajamesc
Sep 8, 2015 06:51 PM
