LOW COMP BOTTOM END FOR S2
accralite pistons 7.8 cr
arp rod bolts
freshly bored block
new piston rings
reground crank with new heavy duty bearings
burton high pressure oil pump
the only parts that aren't new are the pistons which had covered about 3000 miles before the block split hence the newly bored block etc.
the engine is currently in pieces ready for assembly bearings, rings & oilpump are new & still boxed.
£500ovno
call 07747 072489
arp rod bolts
freshly bored block
new piston rings
£500ovno
call 07747 072489
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
