clutch probs on 2wd
Old May 23, 2005 | 11:29 PM
cossiedaz's Avatar
cossiedaz
Default clutch probs on 2wd
hi peeps
i have a alcon 4 paddle clutch in my car and i cant get gears very well, the biting point is on the deck and sometimes the clutch doesnt disengage at all, is there a different cable or ratchet i was sposed to fit to get it to work properly?.
its really doing my head in as i have a fast car which is taking almost a second on gear change and is seriously hindering my santa pod times
my best is a 14.3 @105 mph at a fast stage 3 (330 at the wheels) with the said problem, the car actually slows down during gear change its that bad. i am now running stage four and i feel i could shave a huge amount off that time at my current spec if i could get the clutch to disengage properly.
any advice would be greatly appreciated.
please help
Old May 31, 2005 | 09:52 PM
cozziepj's Avatar
cozziepj
maybe your ratchet if knackered or your cable is stretched?
Old Jun 1, 2005 | 06:08 PM
swerv's Avatar
swerv
personally i would go for a hydraulic conversion and ditch the cable , a few places do these now , i suppose budget for around Ł350 for this depending on what parts you use .
Old Jun 1, 2005 | 06:53 PM
Hectori's Avatar
Hectori
try new ratched first. if it doesnt help, use new cable.
Old Jun 4, 2005 | 02:03 PM
TurboFlush's Avatar
TurboFlush
I would move for the Hydraulic as a good option. I have started to become very impressed with the hydraulics. looking into this myself!
Old Jun 16, 2005 | 02:13 PM
wongthecorrupter's Avatar
wongthecorrupter
have you reset the ratchet
Old Jun 16, 2005 | 05:12 PM
NUTTIN RILLA's Avatar
NUTTIN RILLA
Just poping in on the topic and wondered how you reset you ratchet? my clutch doesnt bite till my foot is nearly off the pedal, my cabel is well and trully burned but i have a new one, just wondering if i need to do the ratchet as well?
cheers
jony
Old Jun 18, 2005 | 08:13 AM
wongthecorrupter
so i have been told by a good source.you have to pull the clutch pedal up as far as it will go towards the bottom of the dash board.hope this helps
Old Jun 18, 2005 | 08:18 AM
wongthecorrupter
my mate put endless clutches in his 3 door bcause bite was poor.we later found out that all he had to do was reset the ratchet
Old Jun 25, 2005 | 11:42 PM
cossiedaz's Avatar
cossiedaz
so do you have to release the ratchet and push the pedal up or just hang on it like a looney?
Old Jun 26, 2005 | 08:00 AM
2001ode's Avatar
2001ode
This is a Ford process
Regards.
Claude
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
gcfcos
59
Oct 6, 2015 05:04 PM
