spluttering/hesitating?
Old May 23, 2005 | 06:06 PM
doggydowg's Avatar
doggydowg
Default spluttering/hesitating?
Hiya guys
Ive just fitted the clutch pedal mod on my mfi rst turbo engine, car only been off the road 1 day, got it all on fine took it for a test drive and went through the gears no slip but then it cut out;-(
I checkd over things and my fuel pump wearnt priming jiggled about 5-6 differnt wires and it started got it home.
Checkd everything all seems ok went for a drive put my boot down in 3rd and it splutterd on boost, tried again and it done the same.
What would cause this, i had to remove the black pipe from metering head to that filter but its back on, my car pops abit on run down any suggestions before i go taking out fuel pump wires to starter etc etc?
Thanks Paul.
