Focus RS rear hubs/stub axles needed....
Hi peeps...
as above, does anyone know of a complete set anywhere??? i've tried ford, they do sell the complete set up's but they are an arm and a leg!!!
I have a set a complete Focus RS rear disc set up, and have a set of hubs/stub axles, but when fitting the brake set up it doesnt quite fit right, so i rang ford and gave across all the part numbers i have for everything (discs, pads, carriers, housings, hubs/stub axles) and the guy said i have everything for a FRS and minus the hubs/stub axle which are from a standard focus-which i'm told an ST170 has the same rear set up, and the FRS are unique....
so if anyone knows of a FRS in a breakers or has a set
let me know or even if you wanna swap my hubs/stub axles they are new and only been on my car!!!
cheers in advance....
rich
rich
Originally Posted by MarkyMark
No its not,
I can do the rear beam, but without brakes nor hub on it, as Iam selling the brakes complete
i phoned FMS on saturday and a lady told me that the FRS you had there had now gone
how much are you selling the FRS set up for!?? wanna swap
think i have found what i want but i am getting a bit more than i wanted, I am getting a Focus RS rear beam, complete with brakes and shocks and springs.....
i will be taking off the hub/stub axle from the beam and selling the rest, anyone interested in shocks/springs and even a FRS beam???
were you getting that from mate?, how much
mark, how much will you do a 2L black top engine for, without the manifolds cos they're not needed....
track.focus'd
Aug 12, 2015 05:53 PM
