MFI 2 EFI
How hard is it to change a old turbo set up (MFI) to EFI ? is it a matter of changing full loom and getting EFI injection unit and getting the sandwich plate for the coversion ??
if so what loom do i need to put in to a mk3 cabby? cos its got an injection loom in now, but its mfi loom.
thanks guys
thanks guys
Best bet if its a mk3 is to use a fiesta turbo engine loom and just extend it to get everything in the desired places. if you untape the mfi loom its fairly simple to separate the engine loom from the loom for lights, fan, horn ect. after you cut the mfi engine loom out you will end up with 4 wires from what i remember, the above website will tell where these need to be connected on the new efi loom.
Hope this helps, Mark
You can use a full efi loom but the ford never made an efi mk 3 so you would have to use a mk4 loom which would need all the plugs changing to connect up to the dashboard ect, could always fit a mk4 dash i suppose but there not as nice as the good old mk3 one
Mark
Mark
ya right m8 thats why ive come out of a mk4 van back in to a mk3 set up
still slightly confused when its comes to wiring is it a matter of conecting all the same colours togther ? by using what ? can some explain in a bit more detail to me
thanks guys
thanks guys
got a FRST loom sorted my m8s got a map sensor there as well and a FRST ECU ? but without getting ecu tested to see if it is annygood anyother way of trying and anyway of telling map sensor is ok ??
thanks
thanks
Not sure how you can test them out of the car mate, easiest option would be to try them in a known working car, if you know anybody with a frst go pull it apart and try them out
had to do that when converting mine, my mate was not best pleased
but it confirmed that all was good.
Good luck
had to do that when converting mine, my mate was not best pleased Good luck
