CAPRI and pinto parts for sale including 45 DCOEs and head
Stage 2/3 ported cylinder head to Vizard guidelines, 46mm pumaracing inlet valves, standard sized exhaust valves reshaped and recut, combustion chambers at around 43cc giving a good healthy 10.5:1 compression ratio, all valve seats and faces recut, new cam bearings, vernier, BLF40.41 cam, stat housing and stat, cold plugs, new cam belt tensioner spring and bolt, ready to bolt on and take off!! Valve guides not worn and have been shortened rather than removed - £300 ono
2 boxed brand new 45 DCOE 152 with 2 x 38mm chokes and 4 x 36mm chokes, assorted jets - £450 ono
Pinto manifold for above - £30
Brand new Genuine Weber twin cable throttle linkage for above with pedal block and cables - £40
Pair K&N filters for DCOE in vgc - £45
Cosworth YB conrods in good nick with bolts, £60 ono
RWD Cossie sump (should fit a Capri and adds baffling to a pinto and an oil return for a catch tank - or a turbo!!!) - £30
Powder coated black narrow rail pinto rocker cover - £10
Painted black wide rail pinto rocker cover - £5
Low mileage water pump with good viscous and top hose - £15
Std pinto conrods with free duff pistons - £10
2.0 block (not 205) - £20
2.0 crank (good) - £20
Brand new shiny breather tank - £20
Deflex front end polybush kit complete - £15 (rear set sold with springs)
-1 inch 145 lb front springs, new from TAS - £10
2 inch lowering blocks - £4
Reasonable 2 litre rad and cover plate - £10
Drivers wing fitted and removed with bad paint reaction - £(a beer)
Bonnet scoops yank style - £5
Paris blue headlamp surrounds and grille - £5
Unpainted MK III grille and black headlamp surrounds (one snapped but not noticeable on car) - £10
MK II "FORD" grille with foglamp holes
- £5
4 spare headlamps - £(a beer as these were free off a mate)
Dash surround in grey / blue with big stereo hole - £5
Dash surround in grey only with std stereo hole - £10
Rear armrests - £free
Dash clocks for spares - £free
Boot carpet and wooden panel - £(a beer)
Standard Capri gearknob - £3
Blue 4 point rally design clubman harness with 2 x "Sparco" blue harness pads - £20
Std laser steering wheel getting on a bit - £10 - c/w a funky RS centre cap intended for a wheel
Stuff still on the car but only just: - offers on all
Stainless steel bonnet prop
Working clock
Most interior trim incl. good sunroof handle!!
Laser doorcards with holes for big speakers and DIY adaptors for 6.5 inch front speakers, rear quarter cards have 6x9s (included)
Prop
Axle
All brakes
Front struts
Glovebox is OK
Dash surround with "Capri" badge and big stereo hole
Working (last tried) dash clocks
Rally design exhaust manifold and exhaust - a tad rusty but good if on a budget! - £30 buyer removes!!!
5 * 7x13 Capri 7 spokes with duff tyres and centre caps
Doors, tailgate, all glass intact, anything else you can rip off if you come and get it!
I also have some XR4x4 sierra front calipers and Mintex pads for these, which are the correct calipers for the 260mm brake kit
Working clock
Prop
Axle
All brakes
Front struts
Glovebox is OK
do you still have the webber linkage? do you know if it's the same as on the 40's? i can't see why there would be a difference? how much posted?
cheers
john
cheers
john
big_Rad
Sep 15, 2017 09:36 AM
rog
Sep 4, 2015 12:10 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
salsheikh
Alloy wheels and ICE for sale
Jul 30, 2015 08:45 PM
