water injection escort rs turbo
Old May 16, 2005 | 08:20 PM
doggydowg's Avatar
doggydowg
Default water injection escort rs turbo
Hello all
Thinking of getting w/i could anyone who is running this on there rst,s say what size jet,s they use and at what boost?
Also what pumps are you running, anyone done any home made kits?
Ive heard of the granada headlight washer pumps being used not sure what jet id use thoe, i plan to run 18psi eventually i already have cossie 2wd front mount cooler and intercooler spray.
Thanks in advance for input Paul.
Old May 17, 2005 | 07:50 AM
glenis's Avatar
glenis
ive heard of it, not sure if anyone on here uses it...
grimmeRST does i think, and Jano odd kidd i think also
Old May 17, 2005 | 09:01 AM
doggydowg's Avatar
doggydowg
Ok cool Grimme is normally quite helpfull might drop im a pm in a bit.
Old May 17, 2005 | 02:02 PM
gus's Avatar
gus
i have it on mine but unfortunatly i have no idea on jet sizes
its a prper wrc spec kit so no granada wash jets pump,
im running a max of 32lb at the mo
Old May 17, 2005 | 03:27 PM
ON-UJAH's Avatar
ON-UJAH
You can set up a simple water spray system for cooling your intercooler/radiator using washer pump/bottle and a spray bar made from brake line tubing or similar.
You can switch it manually or set up a system to only switch at WOT with high ATC's - there are controllers available.
If your talking about injection into the intake system, then it's going to be expensive - using cheap/second hand parts is too risky...a leaking injector could fill the intake with water, which could then get sucked into the cylinder, and blow the headgasket or worse as the engine tries to compress it. Aquamist is probably the best UK supplier of such systems. They have lots of info on their site.
Old May 17, 2005 | 04:29 PM
wildheart's Avatar
wildheart
Theres no substitute for a proper intercooler.
If you need water injection than its obvious you have cooler issues
3i Jim
Nov 20, 2015 05:12 AM
Matt Baxter
Sep 16, 2015 08:30 PM
Vincereese
Aug 18, 2015 03:57 PM
muz
Aug 16, 2015 12:57 PM
adriansaleem
Aug 1, 2015 09:28 PM
