Is this true ?
I was about to buy an in car boost thingy when a guy i know who used to have an rst says that using incar boost controlers blows your turbo as it needs to pump all the way into the car ?!
Is this ture ?
Is this ture ?
I think i need to turn mine down lol im running about 20psi
What psi is safe to run with the following spec:
chipped ecu
-31 actuator
hybrid turbo (not that old)
full mongoose stainless exhaust with 3.5 inch tailpipe
bleed valve
bailey dumpvalve
chipped ecu
-31 actuator
bleed valve
bailey dumpvalve
Thats why i need to get one of those in car things so i can turn it down !
Fook it im gunna get one i really cant see how its gunna blow my turbo. Who else has got one of the in car adjusters ?
it prob has a under bonnet bleed valve, just turn that in and teh boost will set down, if it hasnt maybe the pipes come off the actuator or has split a little
i doubt teh actuator had been set up for 20 psi with you having a std cooler and all
putting a incar 1 on as you are will make no odds cos it will just give you a way of letting more air bleed out, it wont stop the air coming out that the under bonnet 1 (or a leak) is releasing
leave it at 20
and uprate the cooler
http://www.norrismotorsport.co.uk/index2.html
Check the link mate.. Same as this, and never fitted. New freshly painted rocker cover and charge carrier.. fans and hoses, and the intercooler is like new
Retail at 500
yours for 350
Retail at 500
yours for 350
sam mate...turn the boost down to a sensible level - i.e 14psi if that! the car will feel slowler but it will save your engine....oh and no more top speed runs until the car is properly setup...
to get the car setup either go to Grove garage in romford or somewhere like Karl at NMS in coventry and they will do a decent job regardless
bassboy
bassboy
didnt realise it was that turbo, u brought it from a mate of mine in great yarmouth, just saw your pictures in the photo gallery.......
turn the boost down mate, 14 psi and get the fueling checked, its a nice turbo u have there, 20 psi at the current stage will kill it off.
Ford Focus RS Parts for Sale.
Jun 2, 2016 06:46 PM
May 31, 2016 09:28 PM
Oct 9, 2015 07:38 PM
