steering prob
the power steering has gone all notchy/ jerky on my cossie, tried bleeding it and checked the belt, everything seems ok, could it be the pump? worked fine last time i drove it
mine was all notchy when i brought it m8 i changed the oil in reservoir with a suction pump 5 times over the space of a few wks and cured the problem the pas oil had gone all watery looking and brown after a few tank fulls of fresh oil fine m8 well worth a go plus you hardly get dirty i used a large pipet or you can syfhon it out works well to.
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
