Removing Snapped Head Bolt
May 14, 2005 | 05:55 PM
There's about 2" of the bolt still sticking out of the block.
Any ideas on gettin it out, baring in mind it's in fookin tight!
May 14, 2005 | 06:11 PM
Penetrating oil over night and then Stilsons ?
Colin
May 14, 2005 | 06:25 PM
Big pair of Mole Grips?
or use an Easy-out?
May 14, 2005 | 08:35 PM
get ya grinder grind 2 flat edges on it and get a big spanner and try it like that make sure u load it up with wd40 or plus gas
May 14, 2005 | 09:53 PM
May 15, 2005 | 10:43 AM
I brought a special "stud extractor kit" think it was a sealeys one or a grayston from my local motor spares place once as I had one snap too. Got it out first time, no probs!
May 15, 2005 | 03:43 PM
Last time i did that i drilled the bastard out. Be careful the fillings dont go everywhere though.
May 19, 2005 | 09:06 PM
weld a 17mm nut on the top (if you have welder)
hopper350
Sep 4, 2015 12:53 AM
Aug 29, 2015 08:16 PM
ekjim
Aug 17, 2015 08:57 PM
JoeyBoyden
14
Aug 15, 2015 09:51 PM
track.focus'd
Aug 12, 2015 05:53 PM
