What causes....
Old May 14, 2005 | 12:54 PM
RSKim's Avatar
RSKim
Default What causes....
Your exhaust to pop and blow flames (without a flamer kit )
Mines NEVER done it since i had the car, but last night it was doing it LOADS........
Old May 14, 2005 | 12:56 PM
Graceland's Avatar
Graceland
Team HOTHOT!
to much fuel on over-run or the timing is out
but then again, you drive it so soft that all the fuel never gets burnt anyways
crystal blue cos's Avatar
crystal blue cos
overfulling i think?? mine does it alot
andy
Old May 14, 2005 | 12:57 PM
RSKim's Avatar
RSKim
Must admit it does stink of petrol Just thought it was down to the petrol leak I had the other day
Old May 14, 2005 | 12:58 PM
R4N SS's Avatar
R4N SS
banging it off the limiter
Old May 14, 2005 | 01:01 PM
RSKim's Avatar
RSKim
I was well away from the limiter well think I was my rev counter dont work
Ginge !'s Avatar
Ginge !
just finding my feet
kim all cossies flame when giving it large, its cause the zorst has got soo hot the unburnt fuel ignights in the zorst and i stead of the black puff of smoke its now a flame
if ya car over fuels ya will get larger flames, before i had a MSD chip i used to have 4 foot flames come out when giving it some , now there about 1 to 2 foot but theres almost ALWAYS flames in the exhaust
i wouldnt worry tbh unless there really big, cossie flame, if they dont its black smoke
Old May 14, 2005 | 01:03 PM
R4N SS's Avatar
R4N SS
in that case fueling
altho mine popped and banged coming into work the other day and they all heard it in the office as someone was leaving and they were doing a formal presentation
Ginge !'s Avatar
Ginge !
yeah banging it off the limiter makes loads of fuel fly out adn the ignition cuts adn jsut dumps the fuel in still anyway
RSKim's Avatar
RSKim
Its NEVER done it before that was the only thing that worried me a bit......I luv it, esp when people are sat on my arse end
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
PMSL
Graceland's Avatar
Graceland
Team HOTHOT!
kyms got more blue smoke than anything tho
Old May 14, 2005 | 01:05 PM
Ginge !'s Avatar
Ginge !
go to a MOT station and check the CO levels then incase its over fueling
im asssuming ya got a MSD chip, if so the CO should not be over 3.5%, if its a ahmed chip expect it anywhere from 5% to 9%
also means ya gotta keep setting the CO before and after the MOT
Old May 14, 2005 | 01:06 PM
RSKim's Avatar
RSKim
Paul, I aint got THAT much.....
Toe Knee's Avatar
Toe Knee
Chances are the manifold problem would have affected it all the times its been loose as you would have had an air leak!!! Worth getting it down to stus and getting it checked when u get the chance.
Old May 14, 2005 | 01:09 PM
RSKim's Avatar
RSKim
Ye its an MSD chip......my fellas an MOT tester so no probs there
Old May 14, 2005 | 01:11 PM
RSKim's Avatar
RSKim
Any excuse to go see Nic and Stu
Old May 14, 2005 | 01:14 PM
Toe Knee's Avatar
Toe Knee
Well if ur stu can check the emissions get him to do it!!! If he's adjusted the fuel presure/CO or anything when the manifold was loose it might be too high now!!
Old May 14, 2005 | 01:15 PM
RSKim's Avatar
RSKim
We never touched anything on it, but will get him to check it later on
Old May 14, 2005 | 01:17 PM
R4N SS's Avatar
R4N SS
my car had 6.8% CO when it went for its mot last week still passed tho
Old May 14, 2005 | 01:18 PM
Toe Knee's Avatar
Toe Knee
Mine was about 6% bless it
Old May 14, 2005 | 01:19 PM
Ginge !'s Avatar
Ginge !
mines less that 3.5%
Old May 14, 2005 | 01:20 PM
RSKim's Avatar
RSKim
fook no's wat mine is.........
Old May 14, 2005 | 01:37 PM
dave cos4x4's Avatar
dave cos4x4
Could be the inlet manifold fooked.
Mine was and it was popping flames etc....and popping noises quit a lot.
Ended up being the inlet gasket had a big gap in it.
Dave.
Old May 14, 2005 | 01:40 PM
RSKim's Avatar
RSKim
Well all the nuts were loose had them tightened up, it's been doing it since then, fook it im past caring
Old May 14, 2005 | 01:41 PM
Toe Knee's Avatar
Toe Knee
good point dave, if the manifold was loose the gasket could have been damaged or caked in some crap!!!!!!! Should really have had a new 1 put in before it was tightend up so worth geting aswell!
Old May 14, 2005 | 02:11 PM
dave cos4x4
Kim,
get a cometic inlet gasket, this will be a lot better than a standard paper type one.
think these are about £25.
Dave.
Old May 14, 2005 | 05:13 PM
RSKim's Avatar
RSKim
I'll add it to my list Dave thanks
