Poor running ???Help
Old May 14, 2005 | 10:06 AM
Default Poor running ???Help
Right ive had a few problems with me ecos managed to get it runninng without cutting out on boost but she now seems really slugish slow reving and not boosting right any ideas?
Old May 14, 2005 | 12:12 PM
abdr500's Avatar
abdr500
you would have to explane a littel more than that.but cheack the timming and fuel presure it sounds more like you have a bad boost leak get some wd40 or injector cleaner and spray around inlet manfold and if the revs go up you no thers the leak
Old May 14, 2005 | 03:23 PM
Ian M500COS's Avatar
Ian M500COS
turbo..... exhaust housing penny washer?
Old May 14, 2005 | 03:55 PM
The engine feels laboured sluggish to rev even just sat still revving?
Old May 14, 2005 | 05:13 PM
Old May 14, 2005 | 06:32 PM
abdr500's Avatar
abdr500
what have you replaced so far if i was you i would take out the plugs and cheack the coulor and condition and then cheack the sensor that is near the crank pully wich is the is it big turbo or samll turbo model as if its the small turbo it could be the air flow meter sounds like your timming is retarded
Old May 14, 2005 | 07:09 PM
Ive replaced all senser apart from tps Oh and big turbo takern out the plugs and replaced they all looked a little black but nothing major like they allways do.
Old May 14, 2005 | 08:03 PM
SteveB's Avatar
SteveB
I know this is gonna sound a little stupid....... check the bottom pulley is done up... we had a very similar problem last week on an Escort Cos and the pulley was loose (bolt was undone by about 10mm) and the pulley was wobbling about giving a dodgy signal to the CPS
Old May 14, 2005 | 09:59 PM
abdr500's Avatar
abdr500
sounds like map sensor to me also could be the timming is out but youve cheaked that right ??? also the pulg that goes to the cts the blue sensor that screws in to the head at the back it has a blue plug on it cheak that both pins are still ther and makeing conection try tell us what the problem was in the first place like you siad that you managed to get her to run what broke in the first palce what did you fix
Old May 14, 2005 | 10:44 PM
Ryan's Avatar
Ryan
map sensor has been changed.
water temp seems to be reading fine on the SECS monitor.
Old May 14, 2005 | 11:10 PM
pee vee's Avatar
pee vee
been out in it today and its strange as fook
Everything on the SECS monitor seems fine, no irratic readings or anything.
Its got a brand new loom (probs were there before the new loom) so its Not
dodgy connections.
there dont seem to be any misfiring, so it dont seem like its ignition/
BUT Its Laggy as FOOK dont boost hardly at all below 4000 rpm.
Is it possible to have a Stiff/siezed actuator?
on the road it seems like its driving up hill all the time, very laboured,
and then the boost seems to come in very suddenly and all 25 psi at once too
(thats how it seemed anyway)
Old May 15, 2005 | 12:10 AM
Wel i ringed 26 psi out of her tonight racing a pulsar it may be laggy but i still blew the jap crap away lol i think my superiour handling seen him off lmao.But yes all seems fine with it all its baffling me.Its beaten ryan and peevee so far lol.Any more takers lol Hansom reward if someone can solve me problem lol
Old May 15, 2005 | 12:29 AM
Ryan's Avatar
Ryan
thought it may have been the TPS, but shows full thottle sweep on the SECS monitor.
i thought it may have been to do with fuel pressure.
Old May 15, 2005 | 11:47 AM
pee vee's Avatar
pee vee
dunno, would of thoght it would be either misfiring like mad if it was not fuelling right, or plooming smoke out the back or somethin if it was overfuelling?
hmmm, someone must have an idea lol,, its annoying me as well now! lol
Old May 15, 2005 | 04:01 PM
abdr500's Avatar
abdr500
are you runing off a amal valve or a bleed valve or air injectors .this might sound stupid but take a look at you compresor wheel on the turbo that might have a broken fan blade look on both sides exshust aswell it still might boost up but only at very high revs. i had the same problem it felt like the timing was retarded and it turned out to be the ecu/chip fault
Old May 15, 2005 | 04:06 PM
Ryan's Avatar
Ryan
yeah i personally think its an ECU\Map issue.
As the car is in desperate need of a proper live map
Old May 15, 2005 | 04:11 PM
pee vee's Avatar
pee vee
abdr500, we looked at the compressor.. no blades missing, No play in shaft.
turbo was ok.. also looked at boost hose, no holes in it.
Ryan, nige said you thought that.,.. it would make a lot of sense if its an ECU issue!
but it seems to acutally Function ok,. its just sluggish, and dont make boost where it should. but everthing works (eventually)
which is why i thought about actuator or something similar
Old May 15, 2005 | 04:13 PM
Ryan's Avatar
Ryan
apart for the priming issue. Badly needs everything setting up really.
Boost, fuel pressure, and a general look over.
Old May 15, 2005 | 06:46 PM
Where would do this for me at short notice???a live map or somthing?
Old May 15, 2005 | 09:02 PM
abdr500's Avatar
abdr500
on stand still if you was to rev it does it rev clean or ist it still delayed even when revd on idel some how you have low comp it it sounds like it needs degres of spark added at lowere revs
Old May 15, 2005 | 09:40 PM
Ryan's Avatar
Ryan
yes its delayed even when stand still and revving it, i.e not under load.
Comp is stupidly low, far too low IMO.
Old May 15, 2005 | 10:33 PM
abdr500's Avatar
abdr500
not being funny but if its ver low comp then it could be worn bores pistons head head gasket or simpley it was low comp and the advance part on the map chip ecu is not addvanceing the spark to alow it to rev had the same problem turned out to be the chip need more advance of spark so they added 5 degres of spark its now flying but that was because it whent low comp out of the blue it whent bang in the end worn pisstons and bores
Old May 15, 2005 | 10:39 PM
Ryan's Avatar
Ryan
but nothing on the car has changed it suddenly happened one morning when he went to start it, after being out the night before.
well so he says
Old May 15, 2005 | 10:49 PM
Yes nothing changed all just started one day ran really well the night before lol
Old May 15, 2005 | 10:52 PM
ECU Monitor Enthusiast
Nige, If you bring it on thursday, I will have a look.
Old May 15, 2005 | 10:55 PM
I took doug out tonight at weston he didnt say a lot lol Just its not right lol
Old May 16, 2005 | 07:14 AM
Chris Honeywell's Avatar
Chris Honeywell
M8 Take it thursday
Simon is sure to find the fault
Old May 16, 2005 | 01:17 PM
Disabled Account's Avatar
Disabled Account
Actually Nigel I was in bed last night thinking about what it could be and I am CONVINCED that it's a boost leak..........
Why? because I had exactly the same symptoms when my turbo to intercooler pipe had split (under the pipe where you could not see it)....
Baffled me for ages..........as it would (eventually) still make full boost but was very sluggish to build up boost.
I now have an alloy "plug" with an airline fitting attached, borrow it if you want, or come round to my place and we can test it . You disconnect the air filter (90° hose) and fit the alloy plug to it, then do up the jubalee clip, next connect up compressed air line at the SAME PSI as your maxium boost (eg 28 PSI).......If there is an air leak - it will be very obvious AND easy to find
Old May 16, 2005 | 01:39 PM
Disabled Account
Old May 16, 2005 | 02:41 PM
Ryan's Avatar
Ryan
thats an awesome little trick there doug
Old May 16, 2005 | 03:00 PM
Disabled Account
First time you use it, you would prob find that there are air leaks everywhere .....especially plenium joints/inlet manifold......most of the leaks are "minor" but they all add up.......brush soapy water all over the joins and it bubbles up.....It will even show up a leaking/damaged intercooler easily, some times a leak is so bad you can feel with your hand exactly where the air is escaping from
When you fix ALL the leaks it is like your engine has gained 20-30 BHP
Old May 16, 2005 | 03:08 PM
Stu @ M Developments's Avatar
PassionFords Creator
We do that as a matter of course Doug... good to see non pro's using their brains
Old May 16, 2005 | 03:32 PM
digita1dragon's Avatar
digita1dragon
hope you get it sorted Nige, I fookin loved having a ride in it when we did my MOT!
Old May 16, 2005 | 03:35 PM
rs cos's Avatar
rs cos
I'm sure mike could find another use for that
Old May 16, 2005 | 03:55 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Adam,
Yeah, bashing slow paying Irish folk over the head with it .
Old May 16, 2005 | 04:17 PM
pee vee's Avatar
pee vee
cool! i wanna use that ! (for my car of course! )
see how many leaks i got! lol
Old May 16, 2005 | 05:25 PM
LOL a offer off doug to use a bung on me ahhhggg lol it looks like a big bung too eek Sounds like a great idea doug could i borrow it off u or il come over yours and u can Bung me up if u like?
Old May 16, 2005 | 05:48 PM
Stoo's Avatar
Stoo
Hope you get it sorted Nige
Old May 16, 2005 | 06:21 PM
CraigN's Avatar
CraigN
doug can i borrow that sometime
Old May 16, 2005 | 06:29 PM
Disabled Account
PM sent to you Nigel...........
I dont think peeps realise how big this bung actually is -
if your going to stick it in the places suggested then there
will be lots of pain involved LOL:
