s1 box in an s2?
May 13, 2005 | 11:04 AM
s1 box in an s2?
can i do this?on a zvh engine,so would i need a s1 flywheel/clutch?cheers
May 13, 2005 | 11:09 AM
yes you can m8 and no need too change the flywheel
May 13, 2005 | 11:16 AM
thats the answer i needed,cheers fella!
na dont need a different flywheel but will need S1 gearbox brackets and Anti-roll bar
May 13, 2005 | 11:23 AM
where do i get these?how much approx?and do they just fit on?cheers,obviously could get them 2nd hand,BUT is it that expensive?
May 13, 2005 | 11:33 AM
no you don't.....
When I bought my S2 it had an S1 box on it and there was nothing different about the ARB and brackets
May 13, 2005 | 11:35 AM
I'll elaborate....
the gearbox brackets on the S2 only bolt on to the doulbe ended bolts that hold the box together, the S1 box hasn't got these so you just rob them off your S2 box, swap them over and the gearbox mount brackets will fit
just cant see why you would want S1 box and keep the crappy rollbar and cradle
May 13, 2005 | 11:37 AM
I found my S1 box loads better to drive cos of the different gearing and LSD, just a shame I killed it after 2 weeks....
May 13, 2005 | 11:40 AM
well it was 20 years old, what did you expect!
May 13, 2005 | 11:49 AM
very true
Still not something you expect just before a rolling road day though
May 13, 2005 | 11:50 AM
i personally dont see why were messing about with fords when evos are much better cars
oh and personally remember the S1 box has shorter ratios so more wheel spin
i got a S1 box if anyones interested btw
May 13, 2005 | 11:52 AM
I personnaly dont see why anyone even bothers messing about with cars,
boats are much more fun!
May 13, 2005 | 11:55 AM
ya dont get wet when ya car brakes down though or if ya leave ya hand brake off ya aint gotta call the coast gaurd and collect it from malta docks
May 13, 2005 | 11:58 AM
HAHAHA!
very good!
Is that from personal experience?
May 13, 2005 | 11:59 AM
AJC
Oct 8, 2015 11:09 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
deathrider666
Sep 28, 2015 06:12 PM
Russ Payne
Sep 25, 2015 08:29 PM
