Mixing Castrol Magnatec with Mobil 1
Old May 13, 2005 | 10:09 AM
The Gravedigger's Avatar
The Gravedigger
Default Mixing Castrol Magnatec with Mobil 1
I'm feeling a bit of a skank, will I kill my Cossie engine by mixing Magnatec with Mobil 1??
Old May 13, 2005 | 10:48 AM
steve rs's Avatar
steve rs
i think you can only mix oils if it has the same code normally on the back of the container at the bottom not 100% though
Old May 13, 2005 | 10:54 AM
Alloy's Avatar
Alloy
Do not mix oils, ever!
Different oils use different chemicals which could work against each other and break down vital lubricants in the oil.
Old May 13, 2005 | 11:00 AM
The Gravedigger
Damn
mjonathan24
Oct 29, 2015 10:39 PM
Orion_Gav
Sep 29, 2015 04:50 PM
