Headgasket gone after couple of weeks!!
Old May 9, 2005 | 12:07 PM
S1 Barkham's Avatar
S1 Barkham
Default Headgasket gone after couple of weeks!!
Why would this happen??
Had the head skimmed before being replaced.
Am running 14 psi.
Any help will be much appreciated
Would i need a Cometic headgasket?
Old May 9, 2005 | 12:49 PM
GrimmeRS2K's Avatar
GrimmeRS2K
i use the standard ford gasket and i run 21-22psi and its fine, it couldnt of been installed properly, ive heard the standard gasket is normally quite good
Old May 9, 2005 | 12:58 PM
Badman38's Avatar
Badman38
standard gasket is excellent i was running 24psi and nos on my 1.9cvh i've got a cosmetic cvh turbo gasket still in its packaging if you are interested
Old May 9, 2005 | 01:00 PM
S1 Barkham's Avatar
S1 Barkham
What could have made the installation of the gasket faulty??
Old May 9, 2005 | 01:11 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
What make was the gasket that was fitted??
I use an OE gasket at 2 Bar of boost and 300bhp.
Old May 9, 2005 | 01:12 PM
Badman38's Avatar
Badman38
head bolts not tighten properly block not cleaned i had a head gasket go after 3 miles but that was due to me buying a cheap gasket £12 from my local motor factors
Old May 9, 2005 | 01:13 PM
Christian and Beccy
#1 in Spelling Club
Also, if the Correct tightening sequence for the Head Bolts wasn't followed, this could have been the problem. Also, were new Head Bolts used? Were the thick washers fitted under the Head Bolts? The list goes on!!
Old May 9, 2005 | 01:24 PM
S1 Barkham's Avatar
S1 Barkham
It is a Burton Power Gasket
I torqued the head down to the haynes manual specs.
I used the haynes manual bolt tightening sequence, i also used new head bolts with the washers off the old set.
Thanks for all the help, it's still really baffling tho.
Old May 9, 2005 | 01:49 PM
Christian and Beccy
#1 in Spelling Club
Did you use an Angle Gauge to carry out the 3rd and 4th Tightening stages?? Also, it is a good idea to clean the threads in the block and lightly grease both sides of the washer and the threads with Moly Grease first.
Prickly_buzz
Dec 7, 2017 09:52 PM
S3an
Sep 26, 2015 11:39 PM
IainRS1700T
Sep 25, 2015 06:44 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
S3an
13
Sep 13, 2015 10:01 AM
