Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
how do ya measure compresion ratio !!!!!
Old May 8, 2005 | 05:03 PM
Ginge !'s Avatar
Ginge !
just finding my feet
Default how do ya measure compresion ratio !!!!!
as in whats the correct way, ive heard people mention fluid inn the head bowl but can someone tell me what the whole procedure is from start to finish please
Old May 8, 2005 | 05:05 PM
Billabong's Avatar
Billabong
http://mywebpages.comcast.net/mopauly/compression.htm
Old May 8, 2005 | 05:29 PM
lancia delta 6 times WRC's Avatar
also http://www.pumaracing.co.uk/capacity.htm
Old May 8, 2005 | 07:06 PM
AlexF's Avatar
AlexF
www.afracing.com/cr.xls
Alex
Old May 8, 2005 | 07:50 PM
Stu @ M Developments's Avatar
PassionFords Creator
basically, you need to know:
Swept Volume.
This is the volume your piston travels from top to bottom. This is found by doing the calulation: bore area x bore area x 3.14159 x stroke
Clearance volume:
This is teh volume above the piston at TDC. This is best found by filling it with a fluid.
You then do the calculation:
CR = Swept volume + Clearance volume / Clearance volume.
I have pics somewhere to show using a burette i expect if you need to see one.
Old May 8, 2005 | 07:52 PM
POPEYE's Avatar
POPEYE
FAIRY CAKE
he wont be happy until you do stu
Old May 8, 2005 | 07:54 PM
Here's one.
Old May 8, 2005 | 08:05 PM
Ginge !'s Avatar
Ginge !
stu can ya do it with the head on the car
hey im not that bad, just im gonna be doing a few engine builds to practice before i start on the cossie and wanna learn all of it
Old May 8, 2005 | 09:02 PM
Billabong's Avatar
Billabong
Old May 8, 2005 | 09:11 PM
Great piccies Bill
Old May 8, 2005 | 09:13 PM
Billabong's Avatar
Billabong
LOL, they're from the link I posted, seems no one bothered to read it
Old May 8, 2005 | 09:15 PM
Ginge !'s Avatar
Ginge !
bill ive saved it as me favorites actually
many thanks as its got some spot on tips there like the plexiglass
Old Jun 15, 2005 | 08:28 PM
Billabong's Avatar
Billabong
Old Jun 15, 2005 | 08:57 PM
Damo V's Avatar
Damo V
Great Thread
One Q.. Any other way I can measure the clearance volume easily?... otherwise where can i get a burrette from?.. its not like i can nick this stuff from school anymore
Old Jul 5, 2005 | 11:06 AM
PhilM's Avatar
PhilM
PassionBMW.com Member
Stu, do you actually measure the CR with the burette whilst the head is on/
I can't work out how you can do it propperly that way, on a CVH head anyway.
If it was a Cossie or Zetec, yes, fill to the base of the spark plug thread and thats about right (but not perfect, due to the plug not being there).
But on a CVH head, where the sparkplug is mounted off centre, and not at the top of the combustion chamber, I don't see how you can CC it that way? As if you fill the combsution space with water (or whatever fluid your using), it will not propperly fill upto the roof of the combustion chamber? It would spill out of the plug whole long before then?
Old Jul 10, 2005 | 07:44 PM
There are various ways to do it that ive no time to explain, but to tackle purely the issue you have raised, its simple, all engine stands i own "ROTATE"
Old Jul 12, 2005 | 06:59 PM
PhilM's Avatar
PhilM
Haha, doh, sorry Stu, I feel like a plank now
Old Jul 23, 2005 | 03:07 AM
Red16's Avatar
Red16
could always use a syringe
Old Aug 13, 2005 | 06:51 PM
Al Bags's Avatar
Al Bags
1. Head should be removed to do properly .. and supported level.
2. http://www.beecroft-science.co.uk/20...roductList=328
Dont think you will buy a lot cheaper. Last one I used was a 200Ml, but was plenty big enough, reckon a 100 would be OK.
3. Stuff I do ...
Grease the bores a little to seal ring gaps, etc.
Perspex plate greased onto the head surface (to seal off) with a small filling
hole in the centre.
Make sure valves aren't leaking (or seal/wipe off with grease)
Use Paraffin to measure up, not water. You want something like this with low
surface tension!
Old Sep 29, 2005 | 05:12 PM
Moonie's Avatar
Moonie
How do you calculate/allow for the headgasket thickness when calculating the CR with the head off the engine, or is this why you measure the CR with the engine assembled?
Old Sep 29, 2005 | 07:06 PM
Al Bags's Avatar
Al Bags
You gat a thickness figure .. or estimate a compressed depth of the gasket ..
The you use the volume of a cylinder rule using pi = 3.142 to give you the volume of the gasket area when fitted.
eg .. gasket bore 85mm
fitted (compressed depth) 1mm
Volume occupied will be pi x r squared x h
Prickly_buzz
Dec 7, 2017 09:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Chas
Oct 5, 2015 07:13 PM
Mikersturbo
Sep 27, 2015 07:43 PM
IainRS1700T
Sep 25, 2015 06:44 AM
