Another S1 restoration. (update 20/05/05)
this restoration started in about May last year. I'm cut and pasting from my band message board.
Well, here it is the start of the restoration to my beloved Series 1 RS Turbo. It is going to recieve the full works, strip down, body repair, respray, and refit with as many new parts as possible, while still using as many old parts as possible.
Heres some pics of when I first got her/him ... looking minty, but hiding a multitude of sins ... called Brian as number plate ends in Eno. Geddit?
And heres some ones that I took today
under the bonnet....
battery tray is fooked ...
and rest of inner wing..
front o/s crossmember borked, other side in perfect nick
other inner looking pretty shabby
passenger footwell needs some work, although not quite as bad as I though it might be
a whole mess of wires (I had the interior out last weekend)
drivers foot well with 2x6" hole :O
other side of drivers footwell...
passenger seat rear mount gone...
doors in good nick, still had original plastic cover on inside...
under rear seats
more drivers side floor near sill
another view of driver footwell.
spare tyre well in good nick
drivers side bulkhead
guess I need a new scuttle panel then
my dog being as helpful as ever
this project will , and already has, involved lot of blood, sweat and tears. But I can't WAIT to get out driving it again. Reckon it's gonna take about 2 years. All depends on how quick the body work is sorted. [/img]
under rear seats
took wheels off to have a look under, make sure I could actually get the wheels off, and coat evey bolt I can find in WD40 to help shift em eventually...
outside of the tyre well not quite as good as the inside. fuel pump looks like it would disintegrate if I sneezed :O
chassis leg....
arch off, arches not great, but have seen worse.
side skirts off... not too bad...
gave it a bit of a clean, got rid of some greeness.
it's gone from green to brown
chassis leg....
got a bit more done today...
N/S under arch.
evidence of a previous botch job on bottom of footwell.
bumper off, reminder of a small accident with muntjack deer
bit of a hole on the inner wing :O
oops, shouldn't have poked that rust.
driver side. all bolts getting a good soak in WD40
rear O/S arch looks like another not quite finished job done here
look what the body kit was hiding for me
front O/S sills
all under bonnet wiring, all marked up ready for recondition
N/S under arch.
front O/S sills
more today.... was going to start on the wiring loom inside, finished off underbonnet wiring loom, then got carried away with more underbonnet stuff. Can always to the inner loom when it rains
got inlet and exhaust manifold off, drained brake fluid, got the front anti-rollbar off, radiotor, washer bottle, and other engine bits...
At one point I also fitted on one of my brothers Escort Cosworth wheels, and it looked lovely. Need to get an arch to see if the tyres stick out too much?
bit more room to get engine out.
the bits I got off today....
hmmm, were am I gonna put this? it's all one bit :O
looking less and less like an RST all the time
bit more of an update needed. :doh:
Put my name down ages ago on the Housing Association list and completely forgot about it. Then in November got a letter saying one was free. :thumbs:
Got most of the wiring loom out the back of the car, lights, spoiler, window mechanisms etc.
Next job to build me some dollies, so I can wheel the car back out and open the doors to get the loom out of there. Then engine completely out, suspension and tank out, and time to start rust busting!
Home made dollies. (fook paying Ł90 a pair!)
In the garage, and wheels off.
Engine out....
Rear suspension off.
Front suspension off.
Engine out....
Graham, looks like you've got a fair bit to do there but it'll be worth it. Good luck.
I was looking through some of the photo's the other day that I took of mine when I stripped it, brought back memories.
Colin.
Colin.
Originally Posted by WutangRS
To be fair it doesnt look to bad. it looks more grubby than rusty. looks like its been sat for ages though
yeah, not too many big holes, mainly surface rust.
got a few more hours in today
Out for a bit of sun for the first time this year. :O
Brake servo, fuel meter, rack, lines.. all gone
Wiring loom out next job to come.
Recap of problem areas.
Driver side front wing, inside.
Battery tray... I've seen worse. Most of it's still intact.
O/S top cross member. Completely disconntected
Rear o/side sill.
Top of front o/side wing.
N/side inner wing.
Front of n/side wing/chassis leg?
Reasr n/side arch
Passenger seat mount. Only one borked.
Rear footwell, n/side
Driver footwell.
Driver sill. (Crack running along length.)
Passenger footwell.
Behind battery tray.
Tucked back in for now.
[/img]
Rear o/side sill.
N/side inner wing.
Reasr n/side arch
Driver footwell.
Passenger footwell.
[/img]
Bloody Hell mate
You've got your work cut out there!!
By the looks of things your car has spent most of its life in A) The sea or B) in a salt mine
Good luck and mucho respecto!
Couple more hours this afternoon.
Wiring loom "moved" (nearly out, need to remove headlining to finish.
Quarter windows out.
Soundproofing gone, little more brown stuff revealed.
To do...
Windows front/back out
Headlining out
Finish removing loom
Remove all odds n sods nut's n bolts and photo for reference
Then the fun begins.
I have a feeling this project is going to start accelerating quite quickly. getting more time to spend on it now.
To do...
Headlining out
jesus mate you have a challenge on here but good on ya for going for it
i love these cars and its good that people are restoring tyred examples
good luck look forward to seeing the finished product.
once i have done the 3dr cossie(which is nowhere near as bad as your shell
)i am going to do an S1.............dude ,you are an inspiration for what your undertaking........keep it up.......keep updating as i am watching this one with massive interest..it will be definatly worth it
Pugo
Pugo
thanks for all the encouraging posts chaps. this project will be sporadic in it's progress unfortunately. mainly down to cost. but hope fully this will be kept to a minimum doing as much prep as I can myself. might need some welding help if anyones interested.
Hi Graham
I am just about to start the same type of project keep up the good work.
If you are in Amersham (just off J17 M25?) I only live 25 mins away (J11 M25) and could come and give you a hand with bits and bobs if that's any good to you?
Let me know, either post on here, mail me at richard.hanley@edsgfs.co.uk or call 07730 530 765
Speak soon
Rich
Speak soon
Rich
got another hour or two in yesterday. may get the wire brush attachment out today
Windscreen out. Going really well until about 3/4 way round and it cracked.
Wiring loom out. And I'm sure that holes got bigger.
mar
