Borg Warner T5 6 Speed Box & Rear Brake Caliper Upgrade
I know for a fact that there is a 6 Speed version of the T5 and also heard of someone who did the conversion for the 2WD Cossie.
I am wondering if anyone have more information. It is also strange that not many have done this conversion.
I would think that with the price of 2wd Cossie price quite low now more people would be more willing to explore or spend on modifying the cossies.
I know that we can upgrade the rear caliper by getting the AP 4 pots but the issue that has been stopping me. Is the change to a hydraulic hand brake I heard that it would lose pressure after you park for a while.
I have seen a Cossie with a rear upgrade but he retain the cable handbrake anyone knows where I could find a kit to do that ?
as far im aware there are no advantages to fitting this box.
hello mate. i was always told that a t56 6th gear was long than the 5 in the std t5 box. if so you could always get a rack of gears made for it it not impossible as this what i was thinking of doing myself. as for the rear brake what you do is go for a set of ap 4pots plus a spot caliper for the cable. and it will pass the mot. rally design do them and there cheap.
T56 is available with various gearsets and there are also alt top ratios avail on aftermarket
http://www.tremec.com/English/products/T-56.asp
jason_nike
Aug 18, 2019 10:53 AM
track.focus'd
Aug 12, 2015 05:53 PM
