injector pipe order????
Old May 4, 2005 | 10:12 AM
turbo.jon's Avatar
turbo.jon
Default injector pipe order????
just need to double check they are on right way round so starting from first injector near cam belt end which of the 4 holes on top off metering head do it go and for all others too please?????
cheers
jon
Old May 4, 2005 | 11:36 AM
JesseT's Avatar
JesseT
Doesn't matter one bit. The original fuel pipes only fit nicely though in one way.
Old May 4, 2005 | 12:25 PM
GrimmeRS2K's Avatar
GrimmeRS2K
thats how i worked out mine jon, by the way they fit, and lenght
Old May 4, 2005 | 04:54 PM
Moonie's Avatar
Moonie
As above it doesnt matter which port or the metering head goes to either of the injectors as the injection is not sequential, its just a constant controlled flow to the injectors.
Old May 4, 2005 | 06:18 PM
turbo.jon's Avatar
turbo.jon
just trying to rule out fueling problem as its pi$$ing me off now so at least i no its not that then
cheers
jon
mk3ste
Oct 17, 2021 10:09 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
mpilk
Sep 27, 2015 09:21 AM
