stalling when up to temp?
just finished turboing my cab and it starts and drives fine but after 5-10 mins it stalls when stopping at lights or if you put the clutch down straight after accelerating.
if i then try and start it i need to use accelerater a lot to get it to start and it wont idle itself i have to keep the revs up.
anyone had a problem like this?
all i can think of is a problem with metering head?
all help appreciated people
carl
carl
Mine was doing the exact same thing. The little oil breather filter box by the inlet manifold was a bit dodgy and was leaking air, so i replaced it with one i found on an xr3i. Also the dipstick had popped out, could have been either thing really. I was a bit frightened, thought it was something serious!
Mark RS
Oct 12, 2015 06:01 AM
