Passive rear steering - discuss
Ok, a few cars out there have passive rear steering to help with cornering (some active too), it seems a good idea at first, but I was wondering why more cars aren't fitted with it.
If it's any good, would it be technically feasible to build a rear beam/subframe that would work like that for a cossie/rst ?
CheeRS
Greg
CheeRS
Greg
If your talking about 4ws like on the honda prelude it works very well drove a mates on the weekend, also helps the cars handling quite alot he was on par with a few gt4s on a handling circuit so it must do somthing,
MB.
MB.
Originally Posted by NUTS RuS
My Mitsubishi has 2 steering racks - one for the front and 1 for the rear.
It is fantastic round corners and stable at speed
I think that any "home made" system is going to be difficult to get working 100% ALL the time. You'll need loads of extra sensors for steering input, vehicle speed, throttle position, yaw rate etc etc Mucho headaches!
A Passive system where the various parts twist torsionally would probably be a safer bet. On a permanently RWD car, I can't imagine theres a need. A better suspension geo will do 90% of what you're hoping to achieve. A better turn in, and a more stable rear when accelerating out of a corner. Something Im led to believe Cossies arent very good at.
On a FWD car something like a RST will need a complete assembly. Maybe retro fitting a Pug 306 trailing arm will do the job?
Good thread btw. Far too many on here are about straight lines
Thanks Rich w
I don't think a retrofit active system would be possible unless the car was built with it, unless you have loads of money to throw at the problem/solution.
Assuming you have the 90% you are trying to achieve already through better suspension geometry, would the extra 10% be worth it ?
Anyone from Zoo reading this ?
Originally Posted by lancia delta 6 times WRC
Sorry, don't know much about suspension setups
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
