How to tell
Old May 3, 2005 | 01:47 PM
adamS2RST's Avatar
adamS2RST
Default How to tell
If a FRST block is deffo 100% a FRST block? Also, same goes for the head? and also, do the gearbox's come with lsd as standard as I have a feeling they dont?
Old May 3, 2005 | 02:20 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
the head will have inlet ports for injectors
dunno bout the block
and geabox came with LSD
Old May 3, 2005 | 02:32 PM
GUZZLER's Avatar
GUZZLER
L.S.D. was an option for the FRST. bloch should have a threaded oil return.
Old May 3, 2005 | 03:21 PM
gary scott's Avatar
gary scott
The block will have a hole above where the starter motor would normally sit. Its for the fly wheel sensor to sit in.
Also the Oil Return pipe in the front of the block is slightly different, it has a thread type fixing as opposed to a push on fitting like an Escort block.
Hope this helps.
