Esc Cos ICE boot build
My esc cos boot build is up for grabs, even if I decide to keep the car it will be coming out, the pics speak for themselves, there is absolutely NO drilling required for fitment, all fits below the standard parcel shelf all the wiring is hidden below the amp floor, fully carpeted, spare wheel and jack etc still able to be used, this will literally lift out of my car and drop straight into another, no mods required, I will sell it as a whole setup, the job lot, or take it to bits and sell just the MDF / hardwood carpeted build itself, IF you dont want the sub box this will simply unscrew and could just have a smaller sub box fitted or one at the side of the boot to take up less space...
As it stands the box is hinged so to gain access to the amp floor / spare wheel, the back seats flip forward then it just lifts up the sub box itself is fully fibreglassed internally there are no rattles at all
All the speakers are up for grabs, once the amps have gone
There are 3 amps
one for the subs, one for the rear mids and tweeters, a third to run a pair of 8inch mids for the front (these are currently still unfitted)
You wouldnt have to have a 3 amp set up just recarpet the amp floor and run just 1 or 2 for a nice set of std fitment components, there are 2 fans in the amp floor to aid cooling I have never had the stereo cut due to excessive heat, works perfectly obviously can all be heard running no problem
If you interested in anypart of it just post here at the moment I am ideally looking to keep the headunit/multichanger though if everything else or most of it goes I would probably sell the Kenwood EQ/active crossover
Not really sure on what its worth, if I split it all up and whack it on EBay I know I'll get a decent price
let me know what you think....
There are 3 amps
