follow on from (CAN U RUN GREYS WITHOUT LIVE MAP) pics added
Old May 3, 2005 | 12:27 AM
neil d's Avatar
neil d
Default follow on from (CAN U RUN GREYS WITHOUT LIVE MAP) pics added
Old May 3, 2005 | 12:30 AM
Rhys's Avatar
Rhys
looks like head gasket failuer more than poor mapping?
Though i am pissed so who knows
Old May 3, 2005 | 12:33 AM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
not good
Rhys's Avatar
Rhys
opps just noticed the piston too
But how come u had greys etc. with out cut outs in the piston?
What bhp was u running?
Old May 3, 2005 | 12:36 AM
neil d's Avatar
neil d
just trying to load up more pics to show the full dammage
Old May 3, 2005 | 12:59 AM
xr4x4rs's Avatar
xr4x4rs
looks like sum stupid amount of bore wash going on there in number 2
or have you cleaned the piston
number 1 doesnt look to hot either but why is it that black compared t the otheres and the bore doesnt look to good
but id say get it live mapped nxt time
but everyone learns from there mistakes
Old May 3, 2005 | 01:21 AM
neil d's Avatar
neil d
thats my 3rd in 2yrs 4x4rs and yes had cleaned the piston to see the extent off the damage but only just found out that it was a wire rung block and had a cometic head gasket on plus was surposed to be low comp but there is not alot took of the tops in my opinion
Old May 3, 2005 | 01:25 AM
neil d's Avatar
neil d
RHYS apharently it had a 7.2:1 low comp pistons but looking at a set of 7.5:1 pistons today has not ,28psi of boost on greys on near standard compression no wonder it would not run right
Old May 3, 2005 | 06:48 AM
Stu @ M Developments's Avatar
PassionFords Creator
neil d,
Erm... are you sure it was a steel gasket?
Old May 3, 2005 | 08:01 AM
markk's Avatar
markk
neil d,
so whats the problem with that ??? i runmore boost and more compression than std, teh problem with that is that it wasnt setup to do what you were doing with it
Old May 3, 2005 | 09:27 AM
xr4x4rs's Avatar
xr4x4rs
i used to run 25psi on greens and a completely standard engine bar grp a head gasket
got cained everyday and no problems
set up properly you wont have any problems
Old May 3, 2005 | 09:41 AM
That piston has done that due to either oil contamination causing det, or through too much advance or through not enough fuel.
Too much advance or not enough fuel are mapping issues.
oil rings failing due to bore wash and allowing oil past is a mapping issue if thats killed it
head gasket overheating and allowing oil to leak into the chambers could well be a mapping issue too
So whatever the reason for failure, there is a high chance a decent map could have saved it, either that or its just tht the engine is worn out through too many miles.
Old May 3, 2005 | 11:56 AM
On this very subject, ive a car in right now that reminds me 100% why i refuse to do greys OTS.
This car is running greys, T34, 7.4:1 and a BD14.
At cruise.. 4th gear and 40mph its running 8.09:1
At cruise.. 80mph 5th gear its running 8.56:1
On boost, 28Psi above 5500rpm, its running lean at 13.6:1
It melted the same day he bought it or very soon after as i recall?
It cost the fella approx.. wait for it...
Ł250 in fuel to get it here approx 500Miles!! Thats 2miles per Ł1
This engine is faultless and ive spent an hour on it datalogging the outputs.. its a pure mapping fault. Its rich everywhere but where it matters
Old May 3, 2005 | 12:00 PM
markk's Avatar
markk
look at it this way stu , at least when he leaves with his car - he's gonna fookin love you
Old May 3, 2005 | 04:06 PM
neil d's Avatar
neil d
yes Stu the block was wire rung and it had a cometic multi-layer gasket on which inow understand is a big no no ,i did not know as this engine was built for me after the one before had blown it had never been right and i now know why
Old May 3, 2005 | 04:08 PM
If it was built and mapped properly the cometic would have been fine.
Providing the surfaces are flat they work really well.
Old May 3, 2005 | 04:19 PM
Not with wire rings it wouldnt chip, the rings cannot bite into the steel properly to serve their intended purpose.
neil d's Avatar
neil d
but on a wire rung block understand they conflict each others purpose ?
The cometic appear to be unreliable and aint ya surposed to use a diff gasket for coopers rings ?
Old May 3, 2005 | 04:22 PM
Yeah without the rings, like i said "providing the surfaces are flat"
You cant get much less flat than little rings poking out of them!
Old May 3, 2005 | 04:30 PM
whitneyd's Avatar
whitneyd
Wire rings are different from Coppers rings are they not??
neil d's Avatar
neil d
so would the fact that a cometic gasket was used over a wire rung block have caulsed the head to pit and melt away as in pic 2 ?
Ian M's Avatar
Ian M
there is nothing wrong with cometic gaskets if fitted properly.
and that block in the pics isnt coopers rings its just machined to take mig wire.
Old May 3, 2005 | 04:34 PM
neil d's Avatar
neil d
never said it was cooper ring s ian that was mentioned later in the topic
Old May 3, 2005 | 04:37 PM
Ian M's Avatar
Ian M
i know you didnt but dingy said they where.
Old May 3, 2005 | 04:50 PM
coopers rings are different to just wire ringing with mig.
NEITHER should be used with a cometic MLS gasket though.
Old May 3, 2005 | 05:30 PM
Billabong's Avatar
Billabong
Yep, one of them works if done properly, the other is just leaky shite (imo)
Old May 3, 2005 | 05:31 PM
markk's Avatar
markk
Yep, one of them works for a while if done properly, the other is just leaky shite (imo)
Old May 3, 2005 | 05:32 PM
john's Avatar
john
Where is the car now neil at steves again ?
I am so gutted for you to have another go.
Havent seen it since germany and it was running ok then and pretty dam quick.
Will be at next meet as dont do nights no more
Then off to kill me and chip at the ring end of may you have got me addicted
Old May 3, 2005 | 05:35 PM
Billabong's Avatar
Billabong
LOL@Markk
@ guys engine, time to seek advice from a different tuner.........
Old May 3, 2005 | 05:44 PM
neil d's Avatar
neil d
no not going to take it back how many times do i have to have it done to be right ,it was not even running right at germany was only using low boost and it seems to be a compression issue +wrong gasket on fire rung block +bad advice this engine is totally fucked not just a set of pistons mate
Old May 3, 2005 | 05:55 PM
ImaRacing 700's Avatar
ImaRacing 700
Your gasket failed due to wrong one...keep the block and use a std head gasket...proper sorted Probably blew on that cylinder cause it to run lean as all other pistons look mint (so not mapping)
Greys dont need to be mapped imo...i had a collins chip for greys and a did the AFR and ok had a 7% co at idle but once running was very good imo flat out in 4th holding around 10.9 which to be fair on an off the shelf chip pretty good
If you was running a lo comp chip in a higher comp engine then it would be very safe due to less ignition advance used....infact you could have run it on 80 ron fuel
Old May 3, 2005 | 06:00 PM
markk's Avatar
markk
ImaRacing 700,
ahaaaaa the master has spoken
Old May 3, 2005 | 06:34 PM
sidewaysdan's Avatar
sidewaysdan
is it advised to use greys then or not!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old May 3, 2005 | 06:38 PM
Greys are fine and Dandy.. done correctly, as are 8 or them for that matter.
Old May 3, 2005 | 06:47 PM
Ian M's Avatar
Ian M
Originally Posted by markk
ImaRacing 700,
phil, your dreaming if you think theres less advance in a low comp chip quite the opposite infact unless you go to paul hills.
Old May 3, 2005 | 06:52 PM
ImaRacing 700
Sorry wrong way round
Old May 3, 2005 | 06:54 PM
markk's Avatar
markk
so i wasnt just me that noticed then
Old May 3, 2005 | 07:00 PM
DazC's Avatar
DazC
Phil,
I thought there was more ignition advance in the lower CR chips to account for the drop in CR?
DazC's Avatar
DazC
Doh! Too late!!
