RS Turbo Engine Help ASAP
Just rebuilt the bottom end, cranked the engine round and the pistons protude above the block face by about 2 - 3 mm.
Each one is the same, there has been NO change of the crank, conrods or pistons.
Is this meant to happen?? i cant remember when i took the engine apart.
The only reason i ask is that i thought they were meant to be low compression engines and surely this would make them alot higher??
any help much appreciated.
dan
dan
cheers guys that is a relief!
I think they are roughly level with the headgasket, maybe slightly over.
Now my problems just ly with this dam lacquer on the car!!
never am i spraying a car again!!
dan
never am i spraying a car again!!dan
Matt Baxter
Sep 16, 2015 08:30 PM
