Breather system
Old May 2, 2005 | 05:44 PM
matcossy's Avatar
matcossy
Default Breather system
Since i fitted a Bailey breather system to my sapphire after hard acceleration and decceleration it will puff out blue smoke but if i drive easily it doesnt smoke i bought the system second hand so im not sure if i fitted it correctly can any one help please?
Old May 2, 2005 | 07:10 PM
Fiecos Dan's Avatar
Fiecos Dan
my bailys has 4 pipes to it,
2 at top, one to rear of cam cover, one to std breather pot under inlet.
2 at botttom, 1 big goes to under car free air, 1 small is the oil returnwith fits into the bottom rear of block on exhaust.
the kit comes with union to fit in block, and one to be drill on fitted in cam cover
Old May 2, 2005 | 07:22 PM
CarlRsT's Avatar
CarlRsT
You've got it fitted wrong by the sounds.............. think you've got the "to Air pipe" going into your sump
Old May 3, 2005 | 02:33 PM
matcossy's Avatar
matcossy
Thanks for the help
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
