3dr Battery Clamp
Old May 2, 2005 | 03:19 PM
Ryan's Avatar
Ryan
Default 3dr Battery Clamp
How is the battery held in?
Do you have the Bar that goes over the top of the battery?
Or the side one, that clamps onto the base of the right of the battery?
I see alot of 3drs with no top clamp, but mine wont line up with the side clamp hole
Old May 2, 2005 | 03:21 PM
SPADGE's Avatar
SPADGE
Small clamp on the right held in with a 13mm bolt Ryan!
SPADGE's Avatar
SPADGE
ps If yours won't line-up then your battery is the wrong size
Old May 2, 2005 | 03:22 PM
Ryan's Avatar
Ryan
thats what i thought
battery tooo big.
Is the saph battery bigger than a 3dr item
Its a Genuine Ford Silver Calcuim Battery
Old May 2, 2005 | 03:28 PM
SPADGE's Avatar
SPADGE
There should be 2 bolt holes in the tray Ryan to allow for a slightly bigger battery to be fitted. I have swopped saff batterys for 3 door ones and never had a problem!
Old May 2, 2005 | 03:36 PM
Ryan's Avatar
Ryan
yeah there is jules, but just my luck its too big for the inside hole and the too small to use the outside hole, foookin typical
Oh well guess i will have to buy another battery.
Old May 2, 2005 | 03:41 PM
SPADGE's Avatar
SPADGE
Sods law Ryan
Old May 2, 2005 | 07:03 PM
Eagle's Avatar
Eagle
Super Moderator
or get a bigger clamp made up for the outer hole....
Old May 2, 2005 | 07:10 PM
ImaRacing 700's Avatar
ImaRacing 700
I beleive the bolt is a 10mm NOT a 13mm
Old May 2, 2005 | 07:14 PM
Niall.b's Avatar
Niall.b
Saffs had the clamp bit over the top of the battery i believe.
Nov 1, 2015 06:53 PM
martynhomer01
Oct 1, 2015 12:05 AM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
Flatlinedan
Sep 18, 2015 12:41 PM
