Any tips for storing a car for 6 months?
As above , I am going away for 6 months and the car will be staying in a lockup with no electric so there won't be any kind of devices to take moisture out of the air etc.
Should I put it on axle stands to take the weight off the wheel bearings?
The car will be restored to it's former glory when I return in January but I don't want it to rust to hell before I come back
Am more concerned about the mechanical bits and pieces such as the turbo, brakes etc.
Any advice is appreciated
I put mine on axle stands and take the wheels off and put them in bin bags. I also connect the battery up to a battery conditioner. I leave the petrol tank full and I start it up once a month or so and leave it ticking over in first gear to get the oil round things, until it warms up.
Colin.
Colin.
Originally Posted by Freddy_mercury_magic
http://www.carcoon.co.uk/profile.htm
old steel wheels, keep tank full and go in a trainers shop and get some silica gel and bet lots of it in the car to keep the the damp away
when ya get back disconnect the coil and turn the car over for 3 mins so the oils all pumped round
oh and do not leave ya have brake on as that will seize the calipers
theres prob more but that should do for now
Think the main problems are, flat spots on the tyres, moisture in particular and a flat battery.
Solutions: axel stands to take pressure off the tyres, All weather breathable cover? for the moisture problem, take battery out and hook it up to a trickle charger at home.
Hope this helps.
I had my S1 standing for about 2 months, kept it on charge, wheeled it back and forth everyweek and the garage is dry so it was fine and started first time with a roar
Hope this helps.
3mins ginge
fook if the oil aint got around the engine after 30secs of cranking theres sommit wrong
Think most points been coverd. But i wouldnt start it every month and you can build up condensation in the Exhaust so it rusts through and also it can happen in the motor.
As for keep tank full suppose its good idea but always got mine empty
wish my tank was 35 quid
its to stop the tank rusting on the inside as fuel can evaporate and also tanks do rust on the inside
in saying that i use my cossie about once a month and leave my tank empty
Take the plugs out and spray some wd40 in there put the plugs back in
Also change the oil for some cheapo crap that you can dump when you get back
I also use a carcoon at my lock up and there is no electric
I use car batterys
Cannot one of your mates go and change the battery for you
One battery last about a week
I have 4 on charge all the time
I use car batterys
I use car batterys
I use car batterys
