How much am I looking at....?
Old May 1, 2005 | 03:15 PM
Poom's Avatar
Poom
Default How much am I looking at....?
Have found out today that 2 of the nuts holding the turbo onto the manifold are missing! There are the ones on the right hand side!
I have been told that the turbo will need to come off before these can be replaced as it is impossible to get in to fit new nuts!
How much am I looking at for a place to take the turbo off and put it back on properly with new bolts?
Old May 1, 2005 | 03:17 PM
Poom's Avatar
Poom
It is a Series 2 by the way
Old May 1, 2005 | 03:18 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Not alot mate, sounds like an easy job
Old May 1, 2005 | 03:19 PM
Poom's Avatar
Poom
Isnt it time consuming though taking the turbo off and putting it back on again?
If it was the 2 bolts on the other side I could have just chucked new ones on and used that lock stuff to put them on but they are on the side it is hard to get to!
Has anybody had this problem before? IT is making it blow like a beatch which is the main reason for my dirty engine bay
Old May 1, 2005 | 04:13 PM
Poom's Avatar
Poom
Does anybody know how much most places would charge for this?
Old May 1, 2005 | 04:32 PM
Shings's Avatar
Shings
Mate u r having a laugh surely..
a socket set from halfords for 4.99 and about 5 quids worth of studs and bolts from Ford.
Undo boost hoses
Remove water and oild feeds (ok u need spanners for this)
Undo exhaust
about 9 (7 if u have 2 missing) bolts for the manifold to head
take it off.. replace bolts and re fit.
If u take it to a garage IMHO 30 quid TOPS.
Its a 10 minute job
J
Old May 1, 2005 | 09:28 PM
Ginge !'s Avatar
Ginge !
just finding my feet
thinks hes talking turbo to manifold not manifold to head mate, either way i would buy a secondhand manifold and just fit that
taking a turbo off is soooooo easy
Old May 2, 2005 | 09:13 AM
Little Joe's Avatar
Little Joe
Had this done on mine not so long ago when i was having a few other bits done.
I think it cost £10 or something like that.
Old May 2, 2005 | 09:18 AM
EIL132's Avatar
EIL132
Done it in situ before. Pain in the arse, but can be done
Old May 2, 2005 | 11:57 AM
Poom's Avatar
Poom
Where did you get it done mate?
Ad4m RST
Oct 21, 2012 02:23 PM
jaiscossie
Apr 9, 2012 02:23 PM
TomEbbs
35
Mar 21, 2012 09:30 PM
Ad4m RST
Mar 19, 2012 01:14 PM
djleeroy
Aug 5, 2008 07:44 PM
