strut brace on a S2
Old May 1, 2005 | 01:43 PM
Daz-rst's Avatar
Daz-rst
Default strut brace on a S2
ok how to fit one. ive got konis adjustables shocks and the sparco one ive got requitres holes drilling through the turret. is this right what nuts/bolts, sizes do i use????
Old May 1, 2005 | 06:49 PM
glenis's Avatar
glenis
yes thats right
use self tappers... and use rust prevention methods whilst doing the installation
Old May 1, 2005 | 07:51 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
spray-wax,
dont know if you need to take the plazzy wing (arch under wings) off,and use bolts???
Old May 2, 2005 | 10:49 AM
Daz-rst's Avatar
Daz-rst
Default does that weaken the structure
doesnt using self tappers weaken the whole stiffness of the strut brace effect??? as ur only using the strength of the threads of the self tappers to keep it in place??? also the holes seem to line up along the seam on the turret does this cause problems???
cheers
daz
Old May 2, 2005 | 10:59 AM
glenis's Avatar
glenis
use nuts and bolts for best result
but more work is required
Old May 2, 2005 | 11:05 AM
Daz-rst's Avatar
Daz-rst
Default more work???
more work????
Old May 2, 2005 | 11:10 AM
glenis's Avatar
glenis
got to get inside the wheel arch
alloy wheel off, then wheel arch plastic off then drill and bolt through
as opposed to just self-tap screws in from top
Old May 2, 2005 | 11:18 AM
Daz-rst's Avatar
Daz-rst
Default what bolts
what type bolts and nuts would u recommend??? is their a particular angle the brace needs to sit or will it sit only one way????
sorry to be a pain but im useless!!!!
Old May 2, 2005 | 11:21 AM
glenis's Avatar
glenis
just sit it flat, and not tilted at any angle...
make sure its a nice flush flat fit on the struts etc...!
plated or stainless steel nuts and bolts... M6 size i think
Old May 2, 2005 | 11:23 AM
Daz-rst's Avatar
Daz-rst
Default top man
cheers mate top notch!!!!
steve.rst
Mar 15, 2016 08:01 AM
155lee
Oct 27, 2015 04:55 AM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
155lee
Sep 23, 2015 01:27 PM
