my toolbar at bottom screen has moved?
put you mouse pinter in the bottom right hand side of the screen on thtoolbar and then click and drag it either way( to the side or bottom) and your toolbar will go from the botom to the side and back down etc etc , it defo works mate, warlydaddy doesnt know what he's on about man
if thats the case your pulling the mouse pointer to the left then arent you? put your mouse pointer an couple of inchs from the bottom of the screen in the toolbar itself, so your mouse pointer in the toolbar and is 2 inches from the bottom of the screen, then click and hold it while dragging it straight down to the bottom of the screen then when its at the bottom drag it to the left , still keeping it on the bottom of the screen and still holding the button down, the toolbar will drop to the bottom once your mouse pointer gets about 2 inches from the corner of the screen, you must keep the mouse pointer in the toolbar when doin this and you must keep the button pressed down aswell,
SMILER258
Sep 28, 2015 09:04 AM
