Bluetooth......
Old Apr 29, 2005 | 11:40 PM
Dave^'s Avatar
Dave^
Default Bluetooth......
my 2 usb bluetooth dongles turned up to day BUT......
i'm trying to get my laptop to connect to the net thru my pc using the 2 bluetooth dongles to connect the pc to the laptop.....
can't for the life in me suss it out......someone wanna help?
Old Apr 29, 2005 | 11:43 PM
Franco's Avatar
Franco
Mate good luck, it took me fooking ages...................Only ended up doing it by fluke!
Old Apr 30, 2005 | 12:55 AM
Chrissy_bwoy's Avatar
Chrissy_bwoy
i think............
you need to set up a connection link via a spare serial port
i used com9 or summit to connect my nokia to my comp. not exactly the same i know but may be of some use,
try searching the net for pairing phones to bluetooth and you may come up with the solution... or someone cleverer than me will tell you how to do it
Old Apr 30, 2005 | 07:17 AM
Dave^'s Avatar
Dave^
cheers, i'll have a bash later......
btw Chrissy_bwoy, what spec's your car etc? any pics?
Old Apr 30, 2005 | 10:48 AM
Dave Henshall's Avatar
Dave Henshall
or install active sync on them as let the one with the connection be the host, it will try to synchronise yourcontacts and calender etc, but hey - so what.
it uses a virtual serial connection, COM9 i think.
Old Apr 30, 2005 | 05:25 PM
Dave^'s Avatar
Dave^
trying now.....
Old Apr 30, 2005 | 06:43 PM
Chrissy_bwoy
click me siggy dude, all is in the rebuild thread thingy
Old Apr 30, 2005 | 07:00 PM
Dave^'s Avatar
Dave^
Originally Posted by Chrissy_bwoy
i think............
what software are using? car =
Old May 1, 2005 | 01:05 AM
Chrissy_bwoy
im using the gear that came with the dongle, widcomm i think
n cheers
Old May 1, 2005 | 01:11 AM
Dave^'s Avatar
Dave^
ahhh - i found the site for widcomm earlier........but i couldn't find a link to download it from
Old May 1, 2005 | 08:16 AM
DanRSturbo's Avatar
DanRSturbo
Ok, so what you are trying to do, is create a network using 2 bluetooth dongles ? So, the PC has an internet connection already on it ? And you want to use the laptop to connect to the pc, and access the net ?
Old May 1, 2005 | 08:38 AM
AndyRST's Avatar
AndyRST
Dan thats EXACTLY what i want to do too
Now tell me how
Old May 1, 2005 | 02:06 PM
Dave^'s Avatar
Dave^
yep
H E L P ! ! !
Old May 4, 2005 | 10:21 PM
Dave^'s Avatar
Dave^
