Clutch and Flywheel Issue
Old Apr 29, 2005 | 02:10 PM
Dans S2's Avatar
Dans S2
Default Clutch and Flywheel Issue
I'm after some advice please for my S2
The standard clutch is slipping like mad when the boost comes, its
a new clutch and has only done about 1500miles, the car has various mods but i'm not sure which clutch to go for i.e. AP....etc etc also while
i'm doing the clutch is it worth getting the flywheel lightened and balanced??
CheeRS
Dan
Old Apr 29, 2005 | 04:21 PM
Nick-T's Avatar
Nick-T
I've got an AP Racing organic centre plate with a 1600lb pressure plate.
Works very well, doesn't slip
isn't horrible to drive like a paddle but will handle the same power.
www.apracing.com
Oh and do the clutch pedal mod as well to get rid of the ratchet
Old Apr 29, 2005 | 05:05 PM
Blakeya's Avatar
Blakeya
AP six paddle clutch,Mutch better pedal feel & a little easier on the left leg I tis worth getting the flywheel refaced while your at it. To lighten & balance it properly it would need to be done with the crank for a proper job so just a skim would be nice.
Regards
Andy
Old May 16, 2005 | 08:13 PM
Dans S2's Avatar
Dans S2
CheeRS for the advice Andy & Nick..spot on
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Mark_
14
Jan 16, 2016 05:27 PM
