Cossie fuses
Old Apr 28, 2005 | 07:24 PM
Toe Knee's Avatar
Toe Knee
Default Cossie fuses
Right basically 1 of my fuses has melted and car wont run. Not getting a spark so assuming its ignition related but just need 2 check.
Its on the left hand row at the very bottom, 30amp.
Changed it but no joy still so assuming im gonna have to replace the fuse box or wireing oh the joy
So if someone could tell me waht that fuse is for please!!!!!!! the cover isnt off a cossie so chances are what the cover says they are it wont be!!
Old Apr 28, 2005 | 10:07 PM
richm's Avatar
richm
which one is it?
(the one that's been replaced with a remote fuseholder in this pic is for the radiator fans)
Old Apr 28, 2005 | 10:30 PM
Alvyn's Avatar
Alvyn
as above very common on 2 w/d saf for that fuse to melt!BUT cant see that stopping the car from running if it is that one thats blown on yours Ton
Old Apr 29, 2005 | 08:25 PM
Toe Knee's Avatar
Toe Knee
Cheers peeps, yea that was the 1 that was melted Rich cheers mate, never had fan probs before its always worked which is odd so might have to do what u have to make sure its ok!!
Yea cheers Al, was tired that nite and not thinkin!!! Just asumed it was that 1 as it was melted. Turned out to be a 15amp fuse in the car which i assume is ignition related as it stoped the coil sending a spark!!! replaced it and she runs again
Gonna keep her off the road for a bit now and replace loads of service parts to get her running abit better
So would the fans still work with that fuse blown then cos ias i say fans have been fin?! unless it went at the same time lol
Old Apr 30, 2005 | 10:36 AM
Alvyn's Avatar
Alvyn
So would the fans still work with that fuse blown then cos ias i say fans have been fin?! unless it went at the same time lol[/quote]
in a word NO m8
Old Apr 30, 2005 | 08:44 PM
CosKev3's Avatar
CosKev3
That fuses usually melts the plastic of the fuse body or the fuse box itself,
it's not usually blown m8
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
