zvh information
Old Apr 28, 2005 | 07:36 AM
fredy's Avatar
fredy
Default zvh information
hi to all
i own an rst s2 and i would like to make an zvh 2.0 liter convertion on my car but i have some qustions
1. i found on the web a set of rods for zetec priced 360$ but the rod lenght is 5.48" for what zetec are thes rods?
2. where can i find low-comp pistons for zetec outside the uk i prefer in usa ( i dont live in the uk and i prefer to pay $$)
3. what kind of zetec engine should be the base 98 and up or 98 down?
4. is it adiference betwen the us focus zx3 engine and the zetec 2.0 liter up98?
othre sugestion and ideas are welcome
Old Apr 28, 2005 | 08:56 AM
ON-UJAH's Avatar
ON-UJAH
1. These are Focus Zetec 2000+ spec rods. They are only compatible with a 2.0 ZVH, if you also buy suitable pistons. I've chosen this setup and it fits fine into a 94 2.0 Mondeo block. I'm guessing your looking at Eagle rods - nice bit of kit.
2. Off the shelf: Crower, Esslinger, Zetec Central. I had mine made to my spec from Arias (2.1 - 7.8:1). JE Pistons can also do this work.
3. A Mondeo 2.0l Zetec from Mk1 or Mk2. It doesn't matter which, I expect a shagged Mk1 would be cheapest.
4. Probably - either way this isn't the right base block to use.
Don't buy any pistons until you know the block will be OK at the standard bore!
Dont buy any shells until you know the crankshaft journal sizes!
Weld the CVH head to take the Focus multi-layer gasket.
Buy an EFI injection and start saving for some better management if you want the best results.
Weigh your pistons and rods - match the heaviest to the lightest to get the assembled weights as equal as possible.
Good luck mate!
Old Apr 28, 2005 | 09:44 AM
fredy's Avatar
fredy
Default zvh
thanks for the information m8 but i read on burton that the rods leanght are not the same for the pre98 and after 98 zetec
is the main diference is only the rods lenght? can you tell me how much cost your pistons ? and what type of rods do you have?
i have allready an efi stand alone manegment
Old Apr 28, 2005 | 10:06 AM
ON-UJAH's Avatar
ON-UJAH
Correct - later spec rods are longer. You cannot use them with early spec pistons - they will ram into the cylinder head.
You need the correct, later spec pistons (Zetec Central for example) - or get some made to your spec as I have done.
Arias pistons cost about 600 quid with pins. I used Total-Seal rings and had the pistons made to fit them.
I'm using Eagle forged rods. I had Arias make the pistons so the pin fits with a perfect sliding fit to the Eagle bronze bushed little ends. From memory the little end i.d. was 19mm.
I used King bearings in the build.
My pistons are 13cc dished. I have no issues with valve clearance on a standard EFI cam and 45mm intake valves.
Old Apr 28, 2005 | 10:21 AM
JesseT's Avatar
JesseT
Hi fredy!
On-ujah probably meant "Focus Central" and not zetec. They do some cheap forged pistons for the newer zetec rods. If I remember correctly, the length of the Eagle rods don't match the old or the new zetec but are something in the between.
Old Apr 28, 2005 | 10:42 AM
ON-UJAH's Avatar
ON-UJAH
Yeah thats the one - Focus Central.
Eagle rods are 5.483".
There are also early spec rods available but they cost much more. The Eagle kit is a bargain!
Old Apr 28, 2005 | 11:10 AM
fredy's Avatar
fredy
Default zvh
thanks m8
what chnage do i need to do to the head to fit focus headgasket?
Old Apr 28, 2005 | 11:20 AM
ON-UJAH's Avatar
ON-UJAH
It needs welding:
Old Apr 28, 2005 | 08:25 PM
Hansenturbo's Avatar
Hansenturbo
ON-UJAH your pistons and rods looks damn nice how much did they cost ?
Old Apr 28, 2005 | 10:02 PM
glenis's Avatar
glenis
big bucks, at a guess...
mk1turboestate
Dec 2, 2015 08:31 PM
Chas
Oct 5, 2015 07:13 PM
davidfordrs
Sep 23, 2015 02:26 PM
davidfordrs
Sep 21, 2015 04:23 AM
