what should a cossie idle at?
Old Apr 27, 2005 | 12:03 PM
darren.cudd's Avatar
darren.cudd
Default what should a cossie idle at?
just a quicky, as title really
Old Apr 27, 2005 | 12:05 PM
Stu @ M Developments's Avatar
PassionFords Creator
900 - 950 rpm
Old Apr 27, 2005 | 12:15 PM
darren.cudd
ok cheers stu, thought mine was a bit low at 800
thanks
Old Apr 27, 2005 | 12:21 PM
R4N SS's Avatar
R4N SS
mine is a bit high then at 1050
Old Apr 27, 2005 | 12:22 PM
Set it with it HOT, all electrics OFF and the ISC valve disconnected Darren.
Old Apr 27, 2005 | 12:24 PM
The Gravedigger's Avatar
The Gravedigger
Yep mine's always been a bit high, round 1100
Old Apr 27, 2005 | 12:28 PM
darren.cudd
not running the iscv mate always causes me problems tried 2 valves ect ect and it still fooking makes it idle at 1500rpm
always let it warm up before i drive it anyway so just leave the fooker disconected
Old Apr 27, 2005 | 12:30 PM
RSKim's Avatar
RSKim
I don't have a rev counter
Sounds ok though
Old Apr 27, 2005 | 12:35 PM
alan rainbow's Avatar
alan rainbow
darren did karl set your car up
Old Apr 27, 2005 | 12:48 PM
darren.cudd
no mate, he wasnt doing tuning over the winter when i needed it doing
Old Apr 27, 2005 | 01:10 PM
SPADGE's Avatar
SPADGE
I always run mine at around 1200rpm
Old Apr 27, 2005 | 02:32 PM
alan rainbow
karl sets them about 1050-1100 to maintain a high oil pressure
Old Apr 27, 2005 | 05:04 PM
rapidcossie's Avatar
rapidcossie
always like my car idleing at at least 1k if not a tad more
Old Apr 27, 2005 | 05:12 PM
GARETH T's Avatar
GARETH T
thats because you have a problem with your engine loom or a sesnor,,,
there is no reason why it shouldnt idle right
Old Apr 27, 2005 | 05:37 PM
RobCarden's Avatar
RobCarden
358bhp
where do you adjust the idle?
Old Apr 27, 2005 | 05:39 PM
SPADGE's Avatar
SPADGE
The idle adjustment screw is on the throttle body underneath where the hose attaches Rob. It has a lock nut around it.
Old Apr 27, 2005 | 05:45 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Spadge, that's on the 2wd isn't it ? On my 4x4, there's a screw inside a recess below the "entrance" of the throttle body.
Old Apr 27, 2005 | 05:51 PM
ImaRacing 700's Avatar
ImaRacing 700
I personally would run 1000 to 1100 rpm to keep a good oil pressure...especially on a worn engine.
Old Apr 27, 2005 | 05:53 PM
SPADGE's Avatar
SPADGE
Didn't know the 4x4 was any different mate having never used one! but cheers for letting me know
Old Apr 27, 2005 | 06:15 PM
ImaRacing 700
Yes the 4x4 is far better...the 2wd ones have a habit of coming out
Old Apr 27, 2005 | 06:19 PM
DAN P's Avatar
DAN P
mine is a bit low at 900 then will turn it up a bit when its on the road again
Old Apr 27, 2005 | 06:27 PM
frog's Avatar
frog
It might be until is seizes, then it's a pain - not that you have to adjust it every day.
Old Apr 27, 2005 | 07:26 PM
darren.cudd
ok guys bloody hell go away for the afternoon and find shit loads of replys
i'll set her at 950 and see how she goes
gareth, yep i know i have a problem but when im home its a choice between (1) spend all day pulling the loom apart to fix somthing that aint that bigger problem if i just disconect it.....or (2) go out and enjoy driving the wheels off the little sucker
case closed lol
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
fordrallycar
Sep 30, 2015 07:57 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
