handbrake warning light problem...!
Old Apr 19, 2005 | 11:10 PM
glenis's Avatar
glenis
Default handbrake warning light problem...!
why does my handbrake light flicker very often, when going down hill sometimes or off the throttle ??
please help thanks !
Old Apr 20, 2005 | 08:38 AM
cossied's Avatar
cossied
Default light
I thought it was the same light used for brake fluid level. ED
cossied's Avatar
cossied
Default light
Old Apr 20, 2005 | 08:39 AM
glenis's Avatar
glenis
not sure on that one
it flickers randomly tho... almost like a loose connection etc
Old Apr 20, 2005 | 09:13 AM
jdfiesta's Avatar
jdfiesta
Default Re: handbrake warning light problem...!
more than likely it'll be on the same circuit as the brake fluid level low warning. check your fluid level.
JJ
Old Apr 20, 2005 | 02:50 PM
goforit1's Avatar
goforit1
It is on the same circuit. I experienced the problem when the brake fluid level was just at the minimum
stevecfrst1
Sep 30, 2015 05:18 AM
deathrider666
Sep 28, 2015 06:12 PM
Sep 28, 2015 10:05 AM
