Vibration and play sierra cosworth 2WD
Old Sep 21, 2025 | 10:56 PM
Kaydenscossie's Avatar
Kaydenscossie
Projects
Default Vibration and play sierra cosworth 2WD
Hoping I could get some advise. I recently got a sapphire cosworth RWD and it runs fine with no knocks or bangs but at around 65mph+ it seems to be vibrating a lot from the rear. At first j thought it may be the wheel balancing but thats been done and it's still there. I then checked for play on the drive shafts and 1 has slight play around 1mm on the Diff side.
It goes up and down around 1mm inside the diff.
There was also what looks like grease marks over the drive shaft boot where it looks like the boot has been leaking while spinning.
Could this be the cause of the vibration and if not what else can I do to diagnose ?
Thanks is in advance.
Old Sep 23, 2025 | 08:57 AM
Marc sierra's Avatar
Marc sierra
The U joints in the propshaft can also be a problem
Old Sep 23, 2025 | 08:59 AM
Kaydenscossie
Projects
Thanks for your reply mate, but I've checked them for play, dont seem to be any there.... however I have since discovered a little play from the centre mount. Wkndering if it could be that
Old Sep 24, 2025 | 08:02 AM
Marc sierra
The U joints can have 'heavy' points in them. But of course it can something completely different. I would first fix the issue with the drive shaft and see from there.
timsrs
Jul 20, 2020 03:49 PM
COLEYST200
Mar 10, 2017 06:57 AM
Thanasis
Apr 17, 2015 09:06 AM
Mike Kerbey
Mar 9, 2011 08:01 PM
abdr500
Feb 25, 2006 08:32 PM
