Rs1800 gearbox codes.
Old Jul 11, 2025 | 12:54 PM
Shiny Paul's Avatar
Shiny Paul
Default Rs1800 gearbox codes.
Afternoon all.
I need a full gearbox gasket set for an M reg RS1800 we have here, can anybody tell me how I can check what gearbox we have in the car, as I cannot find a number on the box anywhere.
Thanks in advance .
Paul.
Old Jul 20, 2025 | 05:47 PM
james kiely's Avatar
james kiely
92WTBB should be on the casing
The Ford iB5 gearbox identification number is typically stamped on the gearbox housing, near the drain plug or on the side casing. It might also be found on the clutch bell housing,
Old Jul 22, 2025 | 11:32 AM
Shiny Paul's Avatar
Shiny Paul
Thank you for the reply.
I have the following number cast into the gearbox 92WT-7F096-AA
There is no other numbers stamped into the box anywhere.
Are you still saying this is an IB5 box ??
Old Jul 23, 2025 | 04:34 PM
james kiely
as far as im aware thats the code for the rs 1800 box and yes it will be a ib5 with different gear ratios
Old Jul 23, 2025 | 08:38 PM
GVK.'s Avatar
GVK.
I thought the IB5 was the later cable operated 'box? The earlier ones with the rod in the bottom were a BC?
EDIT - BC is the earlier box not B5 as I originally posted.
Old Jul 28, 2025 | 07:12 PM
Shiny Paul's Avatar
Shiny Paul
So we still are not sure which box I have .
I really need to get some gaskets sorted soon and I am guessing the IB5 and the B5 use different gasket sets.
Old Jul 28, 2025 | 08:55 PM
GVK.'s Avatar
GVK.
https://www.burtonpower.com/parts-by...d-gearbox.html
A quick search shows Burton power sell gaskets - try them...
https://www.burtonpower.com/centre-g...CEtAAvsK_HXali
  • Ford Fiesta Mk3 Si 1.6, XR2i & RS1800 1.8 16v 1992-1995
Type BC Fiesta/Escort FWD Gearbox
4 and 5 speed FWD transaxle. Originally designed for the Fiesta Mk1 as a 4 speed gearbox, the 5 speed version was eventually introduced in 1982. It was fitted until 1995 in most FWD applications until being replaced by a similar more refined IB5 gearbox.
Old Jul 28, 2025 | 09:30 PM
Shiny Paul's Avatar
Shiny Paul
That looks very promising, thank you very much.
Old Jul 29, 2025 | 07:38 PM
GVK.'s Avatar
GVK.
From memory (ex Ford tech) there are only 3 gaskets on the box and they seem to sell all 3 , so you should be good with Burtons.
Old Jul 29, 2025 | 07:47 PM
Shiny Paul's Avatar
Shiny Paul
Thank you very much.
Mmitchrs
Apr 11, 2016 05:23 PM
miller318i
Feb 19, 2008 08:28 PM
Charlie Chalk
18
May 2, 2005 04:24 PM
justin.e
Mar 28, 2005 05:59 PM
