Injectors
Old Jun 10, 2025 | 07:55 PM
2much's Avatar
2much
Rs turbo owner
Default Injectors
Hi all, car has just been to a reputable tuners for a set up, cars still on mfi and he's found that it leans out on full throttle, fuel pressure was fine I was told.
he reckons possible injectors are at fault.
Is there an uprated set you can buy for the mfi escort rs turbo.
thanks
Old Jun 11, 2025 | 08:36 AM
haz87's Avatar
haz87
What BHP are you running? Jetronic injectors can cover a lot more fuelling than people give them credit for
Old Jun 11, 2025 | 04:32 PM
2much's Avatar
2much
Rs turbo owner
When there it would go rich in the middle and at idle but was running lean when on full throttle so he recommended trying a new set of injectors so wondered if there was better ones, its not running big power probs around 200 when set up
Old Jun 12, 2025 | 04:57 AM
haz87's Avatar
haz87
Standard injectors are fine for 200bhp. Just change them for a new set - yours are over 30yrs old if originals.
Just make sure you buy from a reputable source, theres alot of fakes about!
Si74
Jul 18, 2011 09:43 PM
dangerousbrian
May 20, 2011 08:14 AM
Max
14
May 8, 2005 12:58 PM
mark-rst
Apr 22, 2005 09:16 PM
