Fans turning on, then not turning off!
Old Apr 5, 2025 | 02:32 PM
RSMK4TURBO's Avatar
RSMK4TURBO
Default Fans turning on, then not turning off!
Fans on the old RS Turbo are switching on before car boils over as they should be but they then never switch off. I may have an airlock or blockage which I need to investigate but how hot should the housing where the fan switch is get? I've noticed with fans on the fanswitch is too hot to touch maybe issue with thermostat?
Old Apr 8, 2025 | 05:48 PM
XR2's Avatar
XR2
The first thing I'd try is to put in a new fan switch.
Old Apr 9, 2025 | 07:33 AM
RSMK4TURBO's Avatar
RSMK4TURBO
Yea I think the car has a lower temp switch fitted will try a standard one, also the car has the fans on separate loom on constant live unlike original setup which was on ignition.
done 300 miles over weekend and on move fans cut off and rarley come on unless in traffic which is great. We can park the car up and fans can then come on after we have walked away and they stay on for 15mins approximately then.been checking battery after and seems ok .
Old Jun 22, 2025 | 01:39 PM
RSMK4TURBO's Avatar
RSMK4TURBO
Changed fan switch and does the same,it's has if once idling stationery the coolant is not being pushed around the system enough. Water pump is new and car is 1.8zvh. Is the standard cvh water pump upto the job?
are there any mods done to the cooling when being converted to zvh that may cause a restriction in the system?
Old Jun 22, 2025 | 06:51 PM
karabeloff's Avatar
karabeloff
Интернет-магазин РыбачОК — это проверенный выбор для всех, кто любит проводить время на водоёмах с удочкой и ценит надежность снаряжения. Магазин доставляет заказы по всей Украине и предлагает оперативную доставку снастей и экипировки в любой регион. В каталоге — товары от проверенных брендов, удобная система поиска и детальные описания, что облегчает выбор оптимального снаряжения под любые задачи.<br />
<br />
Среди самых популярных товаров — спиннинги, мультипликаторы, шнуры, крючки, приманки, эхолоты, рыболовные кресла, палатки, ящики для снастей и термосумки. В наличии — снаряжение как для новичков, так и для профи. Все позиции доступны по низким и честным ценам, а регулярные акции делают покупки ещё доступнее. Если вы ищете, где удобно и недорого купить снасти — РыбачОК вас не подведёт. Подробнее: https://rybach0k.com.ua/ua/a499486-t...pinningov.html
Old Jun 23, 2025 | 09:01 AM
boost monster's Avatar
boost monster
My sons ST170 engine did something similar again with a newish water pump. Turned out to be the impeller on the pump wasn’t tight on the shaft.
Old Jun 23, 2025 | 03:55 PM
RSMK4TURBO's Avatar
RSMK4TURBO
Will have a look into that thanks for info.
lewis.philcox
Jan 17, 2012 10:27 AM
escort_matt
Oct 14, 2010 06:18 PM
steve.rst
Apr 2, 2010 06:28 PM
gwynny
Aug 8, 2007 07:09 PM
220TC
Jun 6, 2004 11:56 AM
