brake/handbrake light on the dash question..
Old Apr 4, 2025 | 04:50 AM
GaryNZ's Avatar
GaryNZ
Default brake/handbrake light on the dash question..
Hi Team,
I've a brake light dash issue im a bit miffed with..
My brake reservoir is topped up correctly and every brake part has been renewed.
When i press the brake pedal, the light comes on for 2 seconds and then goes out.
I can hear a clicking under the passenger side of the dash so assume a relay is working ok.
Why would it be doing this given everything has been renewed?
Its all bled correctly multiple times.
The light works as it should with the handbrake.
Any suggestions / fix appreciated.
Cheers,.
Old Apr 4, 2025 | 09:47 AM
Marc sierra's Avatar
Marc sierra
Does the ABS light also come on, or only the red light?
Old Apr 6, 2025 | 07:07 AM
GaryNZ's Avatar
GaryNZ
The ABS light was staying on, before it got disconnected.
Would the light be coming on because of this?
Thanks Marc.
Old Apr 7, 2025 | 11:42 AM
Marc sierra
In case the boost pressure is not OK, both the ABS light and the red brake light should come on.
jeppo
Ford Focus RS
Apr 22, 2013 12:01 PM
smerth54
Aug 15, 2008 12:07 AM
4x4
Dec 23, 2007 11:43 PM
Stu.H
11
Oct 9, 2005 07:32 PM
