General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
does anyone know if 16inch Escort Cosworth Wheels would fit on a 1997 Fiesta 1.4?
Ive been given some with the offset 61/2Jx16H2 and was wondering if i could put them on without rubbing. Ive got stock ride height and suspension.
Thanks
Yeah, 16-inch wheels could fit, but it depends on the offset. They might rub a bit, especially with stock suspension. Best to test fit them first.
Before installing, measure the clearance inside the wheel arches with your current setup. Add the difference in width and offset of the new wheels to see if they will fit. If you’re unsure, visit a local tire shop—they can help you test fit and confirm compatibility.
