Mk5b RS2000 4x4 PATS issue
Looking for pointers… my Mkb RS2000 4x4 refuses to start, the engine cranks but won’t fire, the PATS light stays on solid from the moment you connect the battery to the moment you disconnect the battery. Im guessing it’s a PATS problem? Can PATS be deleted? I’d even consider an aftermarket standalone ecu.
