engine mapping
Old Apr 17, 2005 | 01:04 AM
Combi_Chris's Avatar
Combi_Chris
Default engine mapping
hi all im totally new here and might not have all the info i need, as far as im aware ive just got my mota back, with a 4x4 wiring loom and ecu , throttle body as well , what will i do next as ive been told its over fuelling and needs a remap, how easy / cheap is this , and where is the BEST place to go local to essex? can i drive the car if im not boosting to get around or am i likely to cook a piston ?
any questions , ill answer the best i can
this is on a cvh rst engine fitted to a combi van
Old Apr 19, 2005 | 11:40 PM
Combi_Chris
thanks for all the replies guys, most dissapointed in this excellent forum
Old Apr 20, 2005 | 02:42 AM
MikeeB's Avatar
MikeeB
Try speaking to someone like jano at oddkiddcreations.co.uk or maybe engine advantages,im no expert so cannot advise what to do but from the sounds of things your running cossie management and i've seen one of oddkidd's cars in fast ford i think so are definately worth a look!!
Old Apr 20, 2005 | 11:36 AM
Combi_Chris
thanks matey , i think ill be getting it done by pts in luton .
Old Apr 20, 2005 | 11:39 AM
EssexBoyRacer's Avatar
EssexBoyRacer
best off posting this in the rs turbo technical section m8, might get a better response there.
Old Apr 20, 2005 | 09:13 PM
DazC's Avatar
DazC
That's because you asked a technical question in a projects section....
Try the technical section or the RST section...
Old Apr 20, 2005 | 10:07 PM
cossiemen's Avatar
cossiemen
Whassup
that's because you are new to this forum, introduce yaself in the muppet room
Old Apr 20, 2005 | 11:16 PM
murfs frst's Avatar
murfs frst
dont go to pts in luton unless you like chimps working on your car
manuel boeckx
13
Oct 3, 2015 02:29 PM
mint_s2
Sep 2, 2015 08:58 AM
Tim Wharton
Aug 30, 2015 05:46 PM
Red_bull
Aug 25, 2015 06:27 PM
track.focus'd
Aug 12, 2015 05:53 PM
